Full Version: TVHeadend 4.2 does not detect adapters latest libreelec
as the title suggests, i cannot use TVHeadend 4.2 , it will not detect my adapter.
My adapter is a HDhomerun.
the "adapters" page seems faulty.
when i click on adapters it doesn't bring down a drop list.
The tuner is detected in:
addon_data\service.tvheadend42\input\tvhdhomerun\adapters\84fd31dbe49f543d68665546a88c2e65
but does not display in tvheadend 4.2
If i install tvheadend 4.0 it works as usual
anyone experiencing this?
4.1 is buggy as well.. it only loads 2 out of a possible 15 pre-determined muxes under ATSC. I've read 4.0.9 is the last stable release. Revert if you can. I build my own on Ubuntu, so it's easy to remove then install a different version.
