Full Version: Music Controls Best Skin
Using Aeon Nox at the moment but music controls dont exists unless you back up to the home screen.
Ive tried a few other skins but apart from Confluence ive not found one that has on screen controls during playback.
To save me trying every skin is there anything that has onscreen controls ?
Im using an Nvidia Shield TV Jarvis with Nvidia remote so no playback buttons on the remote.
I use an ipad myself with the remote control app, so cant really comment.
Let me know if you find one though.
Aeon MQ5 & 6 do. Well, not immediately, but pressing enter/select brings up a menu bar at the bottom of the screen with them all in. This bar remains until you click on a menu item in it, or press back.
It's an easy way to have the buttons hidden most of the time, but available quickly if you need them.
@black_eagle not really... I also only have a remote with very limited keys, and pressing enter/select does nothing. pressing down just scrolls through the list thats displayed. WOW was this really a left out item. Really Kodi has everything in the kitchen sink except a washer for the drain, so to speak.
