Full Version: Apple TV Kodi - MySQL issues
Hi All,
I don't know if this is the correct place to put this thread so please move it if needed.
I just setup a MySQL database for my Kodi Library on my FreeNas machine.
I have put the advancedsettings.xml file in the userdata folder of my windows based Kodi machine and it is working perfectly.
When i put the advancedsettings.xml file in the userdata Folder of my apple TV based Kodi it doesn't work correctly.
It seems to add the Tv Shows but not the Movies and doesn't sync the watched information. I haven't tested the ability to pause on one machine and resume on another (i don't even know if i have/know how to set this up :S)
Does anyone have an idea what may be wrong?
I followed the below How To.
http://kodi.wiki/view/MySQL/Setting_up_MySQL
and
http://kodi.wiki/view/MySQL/Setting_up_Kodi
Thanks,
$tocK
I think i may have found the answer my self
the apple tv Kodi is not running the same version as my Windows Kodi.
The tvOS core testing thread has download links to the corresponding Windows, Mac, iOS, and Linux versions
DanTheMan827, what do you mean?
I can only find tvOS Core testing for apple tv 4, i have an apple tv 2
regards,
Ah, my bad... You didn't specify which so I assumed you were talking about the Apple TV 4
