Would someone be wiling to compile this addon for Raspberry Pi 2/3 so I could test it as a solution for a source for Tvh?
https://github.com/astrilchuk/sd2xmltv/tree/master/kodi
Looking for a way to run an xmltv generator on an openelec/libreelec machine without having to get it from another computer.
-- sorry forget this request. I compiled in a linux virtual machine and it worked just great!!
Asking someone else to compile it for you probably isn't going to get you much.
Google zap2xml, and then google tv_grab_file.
(2016-04-27, 01:52)greenbag Wrote: [ -> ]Asking someone else to compile it for you probably isn't going to get you much.
I know
-- at least it finally forced me to get an ubuntu virtual box up and running...and now I've finally compiled my first item! As a bonus - it works!!
Now I just need to free up some time to start learning to cross compile.
(2016-04-27, 05:20)edit4ever Wrote: [ -> ] (2016-04-27, 01:52)greenbag Wrote: [ -> ]Asking someone else to compile it for you probably isn't going to get you much.
I know
Glad to hear you got it.
I'm not sure about libreelec, but openelec has tools for building an addon right into the image/system. You might want to look at that as well.
edit: let me rephrase that... the openelec source has tools for building an addon into the system.. the tools aren't in an installed version of openelec. Just so you aren't looking in the wrong place.
Grab the openelec source, and see if you can first compile without it, then look at building the addon. There's threads at openelec forums.
