Full Version: [Heads Up] OpenELEC and LibreELEC Skin XML Change
This is a heads up to skinners that the names of the xml files for both OpenELEC and LibreELEC are in the process of being updated* to more accurately reflect the addons they belong to. The current file names will most likely need to stick around through Jarvis, but Krypton should only require the new xml names if you choose to skin either addon window.
Also, please note that a hard-coded color value has been removed from the python code and requires a slight change to one of the labels as shown in the pull request below.
Pull Requests:
*Changes in LibreELEC are live for the current Jarvis and Krypton versions
As an update, changes are live in the latest OpenELEC beta as well.
https://github.com/OpenELEC/OpenELEC.tv/...d243ca03e7
