Full Version: APPLE TV 4 and KODI cache buffer memory size increase
I'm looking a way to increase cache buffer memory size (with internet streams) on Kodi installed on ATV4. This xml works on my Android Tab:
advancedsettings.xml
<advancedsettings>
<network>
<cachemembuffersize>104857600</cachemembuffersize>
</network>
</advancedsettings>
How do I config this to my ATV4 Kodi?
Thread moved to iOS
Thanks for the reply.
I have already tried that Addon (Easy Advanced Settings). It does not work on my ATV4 with sideloaded Kodi. It gives me an error when I try to write an xml file.
I copied the xml file via NFS share from my computer and added it to my Kodi Profiles folder. I did it with instructions I found. The xml file isn't visible in the Profiles folder but as they said in the instructions, that is normal.
The internet streams may be a little bit better now. I still experience some stuttering with them.
Jony
From what I understand, ATV4 works very differently when it comes to all of the XML settings files than any other Kodi platform. I would not expect it to work at all at this point.
