Full Version: Problems with TVH + Kodi on Intel NUC + S960 tuner
Hi guys,
at them moment I'm using latest nightly TVH on an Ubuntu 14 Server with Intel Xeon E3-1265LV2 processor (HP Gen8 Microserver) and DVBSky S960 tuner with latest compiled drivers. As client I've installed latest stable kodi on Intel NUC5CPYH with Ubuntu 15.10.
I thought that I have powerfull enough hardware on both sides (client/server) to get live-tv working without stuttering, but I was wrong. I tried different TVH versions and compiled latest drivers for the tuner on my ubuntu server but it doesn't helped (maybe a little bit...).
So I'm asking you if you use a similiar config and could give me some tips. I assume it's the (crappy) drivers for my tuner which prevents my setup to run smoothly. If so can you suggest me a working dvb-s2 tuner (preferable USB) which works without problems.
Thanks in advance!
PS: I'm trying to get this working for ~1,5 years now. Starting with an Tronsmart android box and a celeron processor in server. Now I'm pretty sure it's not the hardware...
EDIT: I think only CCEs are responsible for that stuttering like in following lines:
2016-04-28 12:25:55.705 TS: 19,2 Astra/11493.75H/arte HD: MPEG2AUDIO @ #5117 Continuity counter error (total 1)
2016-04-28 12:25:55.705 TS: 19,2 Astra/11493.75H/arte HD: MPEG2AUDIO @ #5112 Continuity counter error (total 1)
2016-04-28 12:25:55.705 TS: 19,2 Astra/11493.75H/arte HD: MPEG2AUDIO @ #5113 Continuity counter error (total 1)
When I'm back home again I could test more and post more detailed log outputs.
