2016-04-29, 12:59
I moved house and since plugging in my Rpi2 setup again, it will no longer detect my tuner. I know the device is functioning as Windows detects it and Openelec detects it, but TVHeadend doesn't anymore. I've tried disconnecting it then plugging it back in as other posts have mentioned that has helped, but it doesn't for me.
I did a dmseg dump (below) and can see that OPenelec is detecting the unit but it is now failing to complete the driver install(??)
I formatted my SD card and even tried a fresh install and still have this issue. I've tried different aerial cables, different USB ports (both direct to the Pi and to my USB hub), tried without any other device plugged into the Pi, enabled the "wait for front end" setting in the TVHEadend service and unplugging and replugging in the tuner and nothing is working.
Has there been an update in the last week or two that may have killed my tuner's ability to get detected? I am at a loss as to how to fix this as I'm not a native linux guru so it's kind of hard to troubleshoot adequately.
OpenElec 6.0.3
tvheadend: version 4.0.8 ~ OpenELEC Tvh-addon v6.0.4
Quote: (line 7.234841] usb 1-1.4.1.1: dvb_usb_af9015: command failed=2)[/quote]
OpenElec 6.0.3
Quote:[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.1.18 ([email protected]) (gcc version 4.9.3 (GCC) ) #1 SMP Mon Feb 29 20:48:22 CET 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 8087ff00, node_mem_map ade20000
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (93c0->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 11 pages/cpu @aefb5000 s15488 r8192 d21376 u45056
[ 0.000000] pcpu-alloc: s15488 r8192 d21376 u45056 alloc=11*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 191008
[ 0.000000] Kernel command line: root=/dev/ram0 rdinit=/init BOOT_IMAGE=/kernel.img usbcore.autosuspend=-1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbheight=952 bcm2709.boardrev=0xa21041 bcm2709.serial=0x92ed94a3 smsc95xx.macaddr=B8:27:EB:ED:94:A3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 boot=UUID=0510-6CF0 disk=UUID=06fa04ce-11e4-405d-a058-8a60cdffd0d8 quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 745672K/770048K available (5143K kernel code, 307K rwdata, 1388K rodata, 1836K init, 388K bss, 16184K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
[ 0.000000] lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80668ffc (6532 kB)
[ 0.000000] .init : 0x80669000 - 0x80834000 (1836 kB)
[ 0.000000] .data : 0x80834000 - 0x80880d18 ( 308 kB)
[ 0.000000] .bss : 0x80883000 - 0x808e405c ( 389 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000030] Switching to timer-based delay loop, resolution 52ns
[ 0.000227] Console: colour dummy device 80x30
[ 0.000418] console [tty0] enabled
[ 0.000448] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.00 BogoMIPS (lpj=64000)
[ 0.000469] pid_max: default: 32768 minimum: 301
[ 0.000624] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000641] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001706] CPU: Testing write buffer coherency: ok
[ 0.002240] CPU0: update cpu_capacity 1024
[ 0.002261] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.002274] [bcm2709_smp_prepare_cpus] enter
[ 0.002364] Setting up static identity map for 0x8280 - 0x82b4
[ 0.004478] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.004847] [bcm2709_secondary_init] enter cpu:1
[ 0.004897] CPU1: update cpu_capacity 1024
[ 0.004905] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.005435] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.005717] [bcm2709_secondary_init] enter cpu:2
[ 0.005749] CPU2: update cpu_capacity 1024
[ 0.005756] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.006229] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.006484] [bcm2709_secondary_init] enter cpu:3
[ 0.006515] CPU3: update cpu_capacity 1024
[ 0.006523] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.006607] Brought up 4 CPUs
[ 0.006635] SMP: Total of 4 processors activated (153.00 BogoMIPS).
[ 0.006644] CPU: All CPU(s) started in HYP mode.
[ 0.006652] CPU: Virtualization extensions available.
[ 0.007353] devtmpfs: initialized
[ 0.028591] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.028865] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.029527] pinctrl core: initialized pinctrl subsystem
[ 0.030323] NET: Registered protocol family 16
[ 0.036039] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.050091] cpuidle: using governor ladder
[ 0.063449] cpuidle: using governor menu
[ 0.063896] bcm2709.uart_clock = 3000000
[ 0.068661] Serial: AMBA PL011 UART driver
[ 0.068848] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.069329] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.124829] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.124872] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.125549] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.125566] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.126151] SCSI subsystem initialized
[ 0.126579] usbcore: registered new interface driver usbfs
[ 0.126682] usbcore: registered new interface driver hub
[ 0.126815] usbcore: registered new device driver usb
[ 0.127707] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-19 19:53
[ 0.154907] Switched to clocksource arch_sys_counter
[ 0.166370] NET: Registered protocol family 2
[ 0.167445] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.167588] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.167780] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.167897] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.167960] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.168339] NET: Registered protocol family 1
[ 0.168756] RPC: Registered named UNIX socket transport module.
[ 0.168772] RPC: Registered udp transport module.
[ 0.168781] RPC: Registered tcp transport module.
[ 0.168790] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.307865] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.322647] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.324815] NFS: Registering the id_resolver key type
[ 0.324973] Key type id_resolver registered
[ 0.324986] Key type id_legacy registered
[ 0.325025] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.329134] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.329162] io scheduler noop registered (default)
[ 0.329180] io scheduler deadline registered
[ 0.329232] io scheduler cfq registered
[ 0.331501] BCM2708FB: allocated DMA memory ee800000
[ 0.331543] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.359409] Console: switching to colour frame buffer device 222x59
[ 0.377109] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 1.288239] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.288434] vc-cma: Videocore CMA driver
[ 1.288447] vc-cma: vc_cma_base = 0x00000000
[ 1.288457] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.288467] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.288725] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.302794] brd: module loaded
[ 1.302974] loop: module loaded
[ 1.303536] nbd: registered device at major 43
[ 1.313328] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.315175] usbcore: registered new interface driver rtsx_usb
[ 1.315203] Loading iSCSI transport class v2.0-870.
[ 1.315737] iscsi: registered transport (tcp)
[ 1.316080] tun: Universal TUN/TAP device driver, 1.6
[ 1.316093] tun: © 1999-2004 Max Krasnyansky <[email protected]Qualcomm.com>
[ 1.316423] usbcore: registered new interface driver dm9601
[ 1.316565] usbcore: registered new interface driver smsc95xx
[ 1.316673] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.517177] Core Release: 2.80a
[ 1.517198] Setting default values for core params
[ 1.517244] Finished setting default values for core params
[ 1.717627] Using Buffer DMA mode
[ 1.717641] Periodic Transfer Interrupt Enhancement - disabled
[ 1.717650] Multiprocessor Interrupt Enhancement - disabled
[ 1.717660] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.717697] Dedicated Tx FIFOs mode
[ 1.718071] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 1.718110] FIQ FSM acceleration enabled for :
[ 1.718110] Non-periodic Split Transactions
[ 1.718110] Periodic Split Transactions
[ 1.718110] High-Speed Isochronous Endpoints
[ 1.718135] dwc_otg: Microframe scheduler enabled
[ 1.718193] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80399924
[ 1.718209] WARN::hcd_init_fiq:413: FIQ ASM at 0x80399c94 length 36
[ 1.718226] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf8a6000
[ 1.718303] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.718351] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.718394] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 1.718447] Init: Port Power? op_state=1
[ 1.718457] Init: Power Port (0)
[ 1.718693] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.718712] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.718727] usb usb1: Product: DWC OTG Controller
[ 1.718741] usb usb1: Manufacturer: Linux 4.1.18 dwc_otg_hcd
[ 1.718756] usb usb1: SerialNumber: 3f980000.usb
[ 1.719531] hub 1-0:1.0: USB hub found
[ 1.719599] hub 1-0:1.0: 1 port detected
[ 1.720034] dwc_otg: FIQ enabled
[ 1.720047] dwc_otg: NAK holdoff enabled
[ 1.720055] dwc_otg: FIQ split-transaction FSM enabled
[ 1.720095] Module dwc_common_port init
[ 1.720387] usbcore: registered new interface driver uas
[ 1.720555] usbcore: registered new interface driver usb-storage
[ 1.720846] mousedev: PS/2 mouse device common for all mice
[ 1.721042] i2c /dev entries driver
[ 1.721997] bcm2835-cpufreq: min=600000 max=900000
[ 1.724687] sdhci: Secure Digital Host Controller Interface driver
[ 1.724695] sdhci: Copyright© Pierre Ossman
[ 1.724941] sdhost: log_buf @ ae813000 (ee813000)
[ 1.791589] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.791775] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.792279] hidraw: raw HID events driver © Jiri Kosina
[ 1.794312] usbcore: registered new interface driver usbhid
[ 1.794320] usbhid: USB HID core driver
[ 1.795486] NET: Registered protocol family 10
[ 1.812375] NET: Registered protocol family 17
[ 1.812483] Key type dns_resolver registered
[ 1.812820] Registering SWP/SWPB emulation handler
[ 1.813494] vc-sm: Videocore shared memory driver
[ 1.813510] [vc_sm_connected_init]: start
[ 1.813972] [vc_sm_connected_init]: end - returning 0
[ 1.814180] console [netcon0] enabled
[ 1.814189] netconsole: network logging started
[ 1.816940] Freeing unused kernel memory: 1836K (80669000 - 80834000)
[ 1.861738] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.861866] mmc0: new SDHC card at address e624
[ 1.862324] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[ 1.869985] mmcblk0: p1 p2 < p5 p6 > p3
[ 1.918361] Indeed it is in host mode hprt0 = 00021501
[ 2.084968] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.085134] Indeed it is in host mode hprt0 = 00001101
[ 2.265205] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.265227] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.265799] hub 1-1:1.0: USB hub found
[ 2.265884] hub 1-1:1.0: 5 ports detected
[ 2.545021] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.638540] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.638563] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.641269] smsc95xx v1.0.4
[ 2.684343] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ed:94:a3
[ 2.761610] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 2.865971] usb 1-1.3: New USB device found, idVendor=0471, idProduct=0815
[ 2.865993] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.866003] usb 1-1.3: Product: eHome Infrared Transceiver
[ 2.866013] usb 1-1.3: Manufacturer: Philips
[ 2.866023] usb 1-1.3: SerialNumber: PH00U8iW
[ 2.944969] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
[ 3.040013] usb 1-1.4: New USB device found, idVendor=2109, idProduct=2812
[ 3.040036] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.040048] usb 1-1.4: Product: USB2.0 Hub
[ 3.040058] usb 1-1.4: Manufacturer: VIA Labs, Inc.
[ 3.040836] hub 1-1.4:1.0: USB hub found
[ 3.041091] hub 1-1.4:1.0: 4 ports detected
[ 3.324958] usb 1-1.4.1: new high-speed USB device number 6 using dwc_otg
[ 3.417673] usb 1-1.4.1: New USB device found, idVendor=2109, idProduct=2812
[ 3.417697] usb 1-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.417708] usb 1-1.4.1: Product: USB2.0 Hub
[ 3.417718] usb 1-1.4.1: Manufacturer: VIA Labs, Inc.
[ 3.418637] hub 1-1.4.1:1.0: USB hub found
[ 3.418941] hub 1-1.4.1:1.0: 4 ports detected
[ 3.426237] EXT4-fs (mmcblk0p6): couldn't mount as ext3 due to feature incompatibilities
[ 3.426996] EXT4-fs (mmcblk0p6): couldn't mount as ext2 due to feature incompatibilities
[ 3.450582] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 3.704961] usb 1-1.4.1.1: new high-speed USB device number 7 using dwc_otg
[ 3.802847] usb 1-1.4.1.1: New USB device found, idVendor=15a4, idProduct=9016
[ 3.802871] usb 1-1.4.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.802881] usb 1-1.4.1.1: Product: DVB-T 2
[ 3.802891] usb 1-1.4.1.1: Manufacturer: Afatech
[ 3.802902] usb 1-1.4.1.1: SerialNumber: 010101010600001
[ 3.808426] Afatech DVB-T 2: Fixing fullspeed to highspeed interval: 10 -> 7
[ 3.809023] input: Afatech DVB-T 2 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1.1/1-1.4.1.1:1.1/0003:15A4:9016.0001/input/input0
[ 3.862036] hid-generic 0003:15A4:9016.0001: input,hidraw0: USB HID v1.01 Keyboard [Afatech DVB-T 2] on usb-3f980000.usb-1.4.1.1/input1
[ 3.941633] usb 1-1.4.1.3: new high-speed USB device number 8 using dwc_otg
[ 3.995613] random: systemd urandom read with 71 bits of entropy available
[ 4.010604] systemd[1]: systemd 219 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 4.010958] systemd[1]: Detected architecture 'arm'.
[ 4.011162] systemd[1]: Running with unpopulated /etc.
[ 4.011466] systemd[1]: Set hostname to <OpenELEC>.
[ 4.011755] systemd[1]: Initializing machine ID from random generator.
[ 4.012637] systemd[1]: Populated /etc with preset unit settings.
[ 4.024508] systemd[1]: Unit type .busname is not supported on this system.
[ 4.032434] usb 1-1.4.1.3: New USB device found, idVendor=1058, idProduct=071a
[ 4.032454] usb 1-1.4.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.032465] usb 1-1.4.1.3: Product: My Passport 071A
[ 4.032475] usb 1-1.4.1.3: Manufacturer: Western Digital
[ 4.032485] usb 1-1.4.1.3: SerialNumber: 57584D314536305658373137
[ 4.033219] usb-storage 1-1.4.1.3:1.0: USB Mass Storage device detected
[ 4.033472] scsi host0: usb-storage 1-1.4.1.3:1.0
[ 4.150568] systemd[1]: Configuration file /storage/.config/system.d/storage-TVRecord.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.154237] systemd[1]: Cannot add dependency job for unit TVRecording-cifs.mount, ignoring: Unit TVRecording-cifs.mount failed to load: No such file or directory.
[ 4.157146] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.157229] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 4.157465] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.157526] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.157677] systemd[1]: Reached target Paths.
[ 4.157734] systemd[1]: Starting Paths.
[ 4.157891] systemd[1]: Created slice Root Slice.
[ 4.157952] systemd[1]: Starting Root Slice.
[ 4.158132] systemd[1]: Listening on Delayed Shutdown Socket.
[ 4.158192] systemd[1]: Starting Delayed Shutdown Socket.
[ 4.158478] systemd[1]: Listening on udev Control Socket.
[ 4.158542] systemd[1]: Starting udev Control Socket.
[ 4.158728] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.158791] systemd[1]: Starting Journal Socket (/dev/log).
[ 4.159011] systemd[1]: Listening on Journal Socket.
[ 4.159087] systemd[1]: Starting Journal Socket.
[ 4.159254] systemd[1]: Listening on udev Kernel Socket.
[ 4.159314] systemd[1]: Starting udev Kernel Socket.
[ 4.222671] systemd[1]: Listening on Journal Audit Socket.
[ 4.223079] systemd[1]: Created slice User and Session Slice.
[ 4.223155] systemd[1]: Starting User and Session Slice.
[ 4.223406] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.223471] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 4.223726] systemd[1]: Created slice System Slice.
[ 4.223811] systemd[1]: Starting System Slice.
[ 4.225560] systemd[1]: Mounting Temporary Directory...
[ 4.227551] systemd[1]: Starting udev Coldplug all Devices...
[ 4.286392] systemd[1]: Starting Load Kernel Modules...
[ 4.287402] systemd[1]: Started Debug Shell.
[ 4.290027] systemd[1]: Starting Show Version...
[ 4.290678] systemd[1]: Started Debug Shell on /dev/console.
[ 4.293010] systemd[1]: Starting Setup machine-id...
[ 4.293276] systemd[1]: Reached target Slices.
[ 4.293412] systemd[1]: Starting Slices.
[ 4.296626] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.299297] systemd[1]: Starting Mounting swapfile...
[ 4.301211] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.303446] systemd[1]: Mounting Variable Directory...
[ 4.306723] systemd[1]: Mounting Debug File System...
[ 4.310002] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.310555] systemd[1]: Mounted Huge Pages File System.
[ 4.323148] systemd[1]: Started Remount Root and Kernel File Systems.
[ 4.371789] systemd[1]: Started Rebuild Hardware Database.
[ 4.373529] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.376288] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.377996] systemd[1]: Started udev Coldplug all Devices.
[ 4.404294] systemd[1]: Mounted Debug File System.
[ 4.404600] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.404813] systemd[1]: Mounted Variable Directory.
[ 4.405576] systemd[1]: Mounted Temporary Directory.
[ 4.439260] systemd[1]: Starting Setup Timezone data...
[ 4.440077] systemd[1]: Started Debug /var/log relink.
[ 4.462630] systemd[1]: Started Show Version.
[ 4.467216] bcm2708_rng_init=af9fc000
[ 4.469705] systemd[1]: Started Load Kernel Modules.
[ 4.482501] systemd[1]: Started Create Static Device Nodes in /dev.
[ 4.498461] systemd[1]: Started Setup machine-id.
[ 4.499647] systemd[1]: Started Setup Timezone data.
[ 4.695254] systemd[1]: Started Mounting swapfile.
[ 4.787924] systemd[1]: Reached target Swap.
[ 4.788018] systemd[1]: Starting Swap.
[ 4.789959] systemd[1]: Starting Journal Service...
[ 4.790151] systemd[1]: Reached target Local File Systems (Pre).
[ 4.790274] systemd[1]: Starting Local File Systems (Pre).
[ 4.790378] systemd[1]: Reached target Local File Systems.
[ 4.790451] systemd[1]: Starting Local File Systems.
[ 4.790591] systemd[1]: Started Rebuild Journal Catalog.
[ 4.792935] systemd[1]: Starting Apply Kernel Variables...
[ 4.793268] systemd[1]: Mounted FUSE Control File System.
[ 4.793849] systemd[1]: Mounted Configuration File System.
[ 4.842823] systemd[1]: Started Apply Kernel Variables.
[ 4.896385] systemd[1]: Started Journal Service.
[ 4.944570] systemd-journald[187]: Received request to flush runtime journal from PID 1
[ 5.033932] scsi 0:0:0:0: Direct-Access WD My Passport 071A 2011 PQ: 0 ANSI: 4
[ 5.037311] scsi 0:0:0:1: Enclosure WD SES Device 2011 PQ: 0 ANSI: 4
[ 5.037670] sd 0:0:0:0: [sda] 976717824 512-byte logical blocks: (500 GB/466 GiB)
[ 5.041302] sd 0:0:0:0: [sda] Write Protect is off
[ 5.041330] sd 0:0:0:0: [sda] Mode Sense: 2b 00 10 08
[ 5.045274] sd 0:0:0:0: [sda] No Caching mode page found
[ 5.045322] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.054426] sda: sda1
[ 5.059519] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.520160] random: nonblocking pool is initialized
[ 6.255045] Console: switching to colour dummy device 80x30
[ 6.298397] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.534988] Registered IR keymap rc-rc6-mce
[ 6.535464] input: Media Center Ed. eHome Infrared Remote Transceiver (0471:0815) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/rc/rc0/input1
[ 6.536355] rc0: Media Center Ed. eHome Infrared Remote Transceiver (0471:0815) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/rc/rc0
[ 6.560919] lirc_dev: IR Remote Control driver registered, major 244
[ 6.597855] usb 1-1.4.1.1: dvb_usb_v2: found a 'Afatech AF9015 reference design' in warm state
[ 6.680826] IR SANYO protocol handler initialized
[ 6.680830] IR NEC protocol handler initialized
[ 6.680832] IR XMP protocol handler initialized
[ 6.680835] IR JVC protocol handler initialized
[ 6.682006] input: MCE IR Keyboard/Mouse (mceusb) as /devices/virtual/input/input2
[ 6.686173] IR MCE Keyboard/mouse protocol handler initialized
[ 6.686199] IR Sharp protocol handler initialized
[ 6.687591] rc rc0: lirc_dev: driver ir-lirc-codec (mceusb) registered at minor = 0
[ 6.687618] IR LIRC bridge handler initialized
[ 6.688368] IR RC6 protocol handler initialized
[ 6.688565] IR Sony protocol handler initialized
[ 6.689237] IR RC5(x/sz) protocol handler initialized
[ 6.728865] mceusb 1-1.3:1.0: Registered Philips eHome Infrared Transceiver with mce emulator interface version 1
[ 6.728893] mceusb 1-1.3:1.0: 2 tx ports (0x0 cabled) and 2 rx sensors (0x1 active)
[ 6.729083] usbcore: registered new interface driver mceusb
[ 7.234841] usb 1-1.4.1.1: dvb_usb_af9015: command failed=2
[ 7.765910] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.766253] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.826800] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 7.855420] fuse init (API version 7.23)
[ 7.871956] usb 1-1.4.1.1: dvb_usb_af9015: command failed=2
[ 8.508951] usb 1-1.4.1.1: dvb_usb_af9015: command failed=2
[ 9.146194] usb 1-1.4.1.1: dvb_usb_af9015: command failed=2
[ 9.146219] usb 1-1.4.1.1: dvb_usb_af9015: eeprom read failed=-5
[ 9.146256] dvb_usb_af9015: probe of 1-1.4.1.1:1.0 failed with error -5
[ 9.146414] usbcore: registered new interface driver dvb_usb_af9015
[ 9.376486] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.379538] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
