2018-09-02, 11:22
(2018-09-02, 09:56)pjotr69 Wrote: [ -> ]Easy way. Click this link -> https://github.com/the-black-eagle/scrip...r/releases(2018-09-01, 19:06)black_eagle Wrote: [ -> ]Probably my ignorance but how can i instal this addon?(2018-09-01, 15:16)pjotr69 Wrote: [ -> ]" You'll find it listed under Program Addons as Video Database Cleaner. When you click Run you'll be shown the confirmation page of what will be cleaned based on your settings.. Check it looks right and then hit OK. The clean will then happen, followed by KODI's own Clean Library function.""Yes, it still exists and was recently updated to support Kodi 18 (thanks to @Kib) !!
Does anyone know if this kind of datbase cleaner still exist?
(i have a full database and can't clean up any more.)
You can either download the zipped file from https://github.com/the-black-eagle/scrip...se.cleaner and install (making sure 'use unknown sources' is enabled), or you can download and install the repo (https://github.com/the-black-eagle/repos...blackeagle) and then install the cleaner from there.
Can't find your link or "database Cleaner" or even your repository.blackeagle in "install from repository"
Did enable unknown sources.
Click on the 'script.database.cleaner.zip' to download it to your machine. Save where you can easily find it. Start kodi and install via the addon manager -> install from zipfile.
