Full Version: Show header setting not staying on after restarts.
Love this skin btw. The one annoyance right now for me is what the title says. When I enable the show header, it works fine but if I force close kodi or simply restart my firetv, the show header setting is turned back off again.
Is there a way to fix this or is it a bug currently? Or I could just be dumb, idk lol.
Any insight on this would be awesome, thanks!
Most likely you're not shutting down Kodi correctly, which would allow the settings to be saved. Use the shutdown menu rather than forcing it to close.
