Full Version: 16.1 Weird MYSQL Issue
I'm not real sure where to post this. Windows or Linux.
I've got the following
Windows 7 - Fresh Install - Fully Patched - x64
Windows 10 - Fresh Install - Fully Patched - x64
Ubuntu 16.04 - Fresh Install - Fully Patched - x64
MySQL Shared Library
I've started a new setup completely from scratch as I just moved all my media and wanted a clean start.
MySQL is setup and working fine.
On first startup on the Windows 7 machine all databases and tables are created and an import of media works fine.
Windows 10 machine sees library just fine.
Ubutnu machine sees library just fine.
Here's comes the issue though. If you close and reopen Kodi on either Windows machine after the Ubuntu machine has touched the database they don't load (well technically they load but it takes like 20 minutes and it's using a local library instead of mysql). I can monitor the MySQL server and see them start the initial query.
Without the Ubuntu box both windows boxes work fine (a clean DB is required).
This was working fine on 16.0 and I currently have a nightly of 17.0 running on all machines and it's working fine. So there's something with 16.1 causing this issue.
Any ideas?
Serideru,
Sorry I don't have an answer to your problem, rather a question...
My experience with is with 16.0 and 16.1 that MySQL is soooo much slower than what it was on 15.2?
I reverted back to 15.2 as when I click on TV shows in 15.2 it takes 2 seconds to show the entries, and 16.x + it takes 15 to 20 seconds at least, what is your experience on this?
debug logs needed.
