2016-05-04, 21:48
I am a big fan of Kodi, I installed Kodibuntu asap because i dont like slow crapy windows on it.
i am doing the update as we speak using:.
Now its asks me if i wanna update the lsb config, as i am not aware of the changes on this system i kept the old one (default) does this matter?
Now the second question, i am using a vga to hdmi converter. Not the best thing to do, i know.
Anyway the screen seems to connect and disconnect, only on the vga port. works fine on windows so im guessing its the driver.
I hope this update would fix that.
Any suggestions?
sudo apt-get update && sudo apt-get upgrade -y && sudo apt-get dist-upgrade
Any suggestions?
