Full Version: Hide TV from main menu but use keymap instead?
Is it possible to remove the TV button from the main menu but still be able to use it, through keymaps?
You should be able to remove the TV tab in Settings - Appearance - Skin - Settings - Home window options, then use keyboard shortcuts. [E] will bring up the EPG.
Keyboard_controls (wiki)
Nope. It's not there. I'm using Confluence skin. If I go to System > TV > Enabled • but then none of the keymaps work for TV.
