Full Version: YouTube2 0.93 script memory leak
When using You tube2 the 7mb are used but when I close it the 7mb dont return. Im thinking theres some kind of memory leak. I start with 40mb at startup, use you tube2 0.93 and have 33mb, I close it and have 33mb. Other python applications are fine.
Problem solved... the memory just takes a few minutes to recover.
