2016-05-07, 13:35
Hi Guys,
So yesterday i spent the majority of the day transfering my kodi jarvis data from my 1080p htpc to my nvidia shield box. I thought i would get everything working straight from here so that i wouldnt need to use the windows based htpc box anymore.
Im using the kodi app from the playstore on the shield.
Once my library was back up and running and everything looked the same as my htpc, i started doing some tests.
The first issue i found straight away was HD AUDIO. I could not get DTS-HD or dolby trueHD to display correctly to my Arcam avr550 receiver. Neither could i get Dolby Atmos to work!!! Was very dissapointed ?
I have 7.1.4 channels and it was also downgrading everything to 5.1.
After some messing around in the settings i got 7.1 to work with PCM, however everything i tried (pass through or not) just didnt give me my HD audios that i was after!
I then searched this forum and found the nvidia shield sideloaded builds to test out passthrough audio.
The thread seems to be closes now, i think with the last build released in april. So my question was, was the features in this branch added to the playstore build yet? Or i have to download and sideload a custom build for this?
Also there was three build options and i was a bit confused as to which one is required for the Shield?
Android ARM (Most devices)
Android x86 (Nexus Player for example)
Build date: 8th March 2016 (16.1-RC1)
Second issue, regarding the picture quality. Im outputting 4k resolution however the colors seem washed out and very dull compared to my windows 1080p htpc box!!
Is there any reason for this and anyway to fix it? I tried a few blurays and the colors were definetly less sparkly then the 1080p htpc, this was on normal 1080p content but the 4k should atleast equal or upscale to display a better picture and not worse right?
Thanks for your help guys!
