2016-05-08, 13:28
I could need some help integrating xmltv within tvheadend.
I would disable OTA (EIT) because of continious counter errors, when OTA is triggered. Respectively I will only use OTA for channels which are not integrated within my XMLTV provider.
So would I did so far:
I installed xmltv-utils so that I'm able to use tv_grab_eu_egon.
Afterwards I run this command with --configure and placed the necessary url and channels.. URL --> root-url=http://xmltv.xmltv.se/channels.xml.gz
I think this is working so far without any problems. I'm trigger the update with a separate Cronjob:
This cron is triggered from the user hts.
Additionally I activated the Internal Modul: "Internal XMLTV: German speaking area (Egon zappt)"
Extra arguments: --config-file /home/hts/.xmltv/tv_grab_eu_egon.conf --output /home/hts/.xmltv/xmltv.file
For any mapped channel, I've added EPG Source from XMLTV and activated the source under EPG Grabber Channels.
The problem I have is, that I don't get the EPG in kodi displayed (or e.g. Android TVHeadend Clients..)
I just had the EPG from OTA Grabber.
Did I forgot something or may I did something wrong?
May this is the problem?
The file (--output) is filled with data:
I would appreciate any kind of help.
*/30 * * * * /usr/bin/tv_grab_eu_egon --quiet --config-file ~/.xmltv/tv_grab_eu_egon.conf --output ~/.xmltv/tv_grab_file.xmltv
May 8 13:20:18 kodi tvheadend[1890]: /usr/bin/tv_grab_eu_egon: no output detected
May 8 13:20:18 kodi tvheadend[1890]: /usr/bin/tv_grab_eu_egon: grab returned no data
[email protected]:/home/hts/.xmltv# head -10 tv_grab_file.xmltv
<?xml version='1.0' encoding='UTF-8'?>
<!DOCTYPE tv SYSTEM "xmltv.dtd">
<tv>
<channel id="13thstreet.de">
<display-name lang="sv">13th Street Germany</display-name>
<icon src="http://logos.xmltv.se/13thstreet.de.png"/>
</channel>
<channel id="2.eurosport.de">
<display-name lang="sv">Eurosport 2 Germany</display-name>
[email protected]:/home/hts/.xmltv# wc -l tv_grab_file.xmltv
232684 tv_grab_file.xmltv
