2016-05-09, 15:29
2016-05-13, 02:20
Skin need support, MQ7, Marcos used filename for show flags.
.atmos.
.atmos-
.dts-x.
.dts.x.
.dtsx.
.dts-x-
.dts.x-
.dtsx
.atmos.
.atmos-
.dts-x.
.dts.x.
.dtsx.
.dts-x-
.dts.x-
.dtsx
2016-05-17, 19:29
(2016-05-13, 02:20)Wanilton Wrote: [ -> ]Skin need support, MQ7, Marcos used filename for show flags.
.atmos.
.atmos-
.dts-x.
.dts.x.
.dtsx.
.dts-x-
.dts.x-
.dtsx
I am using Estuary MOD which supports these extensions but I notice that .3D.atmos works but .atmos alone doesn't work.
2016-08-26, 13:27
Same problem here. After upgrading my home theater to a Atmos capable receiver I took the time and renamed all corresponding movies and had to manually add them to the library. I assume it's scraper related and has nothing to do with the skin which only takes the info for displaying the correct logos.
