Full Version: Amber skin - Icons view show fanart as background
Was wondering if someone might be able to help me out.
Im trying to find a way to edit the 'icons view' so that it shows fanart in the background when a movie is highlighted. instead of the current black background.
If someone could point me in the right direction of code that would be great!!
http://i.imgur.com/eDkO9HS.jpg
I can't describe exactly what you want right now but what I am working on at the moment is a global fan art switch.
This will allow you to see the fanart for widgets on the home screen (tested and working) and also the fanart for the listitem on any of the other windows, at the moment I have only done this for the Krypton testing branch and I doubt I will have the time to backport this to Jarvis as it is quite involved.
If you want to try it yourself you can try editing the Includes.xml file and find the Fanart_Art include, this has a switch which will not show fanart for views 52 = biglist, 55 = big panel and 53 = icons (grid), if you remove the 53 condition then the fanart will show in the icons view but it will not have a diffuse layer applied so it is a bit in your face, you may want to have a look at an overlay image to soften it, but I'll leave that for you to play with :-)
(2016-05-12, 12:06)joethepartylion Wrote: [ -> ]if you remove the 53 condition then the fanart will show in the icons view but it will not have a diffuse layer applied so it is a bit in your face, you may want to have a look at an overlay image to soften it, but I'll leave that for you to play with :-)
This worked perfectly - I have removed 53
But as you have said it might be abit in your face...
With being new to all this, how would i go about maybe making it like 10-20% less opacity for the fanart?
Appreciate your help
(2016-05-12, 15:54)NaDs Wrote: [ -> ]This worked perfectly - I have removed 53
You can try adding something like the below to View_53_Icons.xml under the <include name="View_53_Icons"> line
<control type="image" description="background overlay">
<visible>Control.IsVisible(53)</visible>
<include>VignetteFade</include>
<left>0</left>
<top>0</top>
<width>1920</width>
<height>1080</height>
<texture>common/VignetteStage.png</texture>
</control>
It may not look perfect as I haven't finished the textures needed yet but it will give you a start.
View_53_Icons.xml seems to be on Krypton but not on the original Amber skin that I am trying to edit.
I can only see View_53_Grid.xml
I have located VignetteStage.png in textures so I will be able to edit this image to get the correct opacity I am after.
If you could explain where to add code in the original Amber skin that would be great.
Got it working Smile
