2004-04-12, 19:40
hi... i built an xbox xbmc implementation for some friends to use as media center, and am installing it during easter break while i am back home visiting.
they have a tv that can do component in, so i have the hdtv video cable pack for them. i had setup the config on my hdtv at home which can do 1080i, and neglected to change the settings before i left. now, when i try and use the hdtv cable, their set, which can only do 480p wont display the video, and i can't reset it in the dashboard since i can't see anything when i have the hdtv cable plugged in.
i can plug in the normal composite cable and use it, but running the ms dash in this config doesn't let me change the hdtv settings!
is there a way to let me override the ms dash video settings from the xbmc config to force 480p mode? or does anyone have another suggestion for me?
thanks
mike
thanks
mike
