2016-05-12, 16:13
dear kodiers,
i´d like to bring up my topic, cause i cant find the end of the tunnel. i did try to install all the necessary drivers but no solutions.
please have a look at my crashlog. its a debian - latest stable version (jessie)
everytime i start kodi i get this error...
CLI
root@ls1:/home/hornaus# kodi-standalone
ERROR: Unable to create GUI. Exiting
Segmentation fault (core dumped)
Crash report available at /root/kodi_crashlog-20160512_161000.log
Crash report available at /root/kodi_crashlog-20160512_161001.log
Crash report available at /root/kodi_crashlog-20160512_161005.log
/usr/bin/kodi --standalone has exited uncleanly 3 times in the last 8 seconds.
Something is probably wrong
LOG ITSELF
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Don Mai 12 15:59:27 CEST 2016
Kodi Options:
Arch: x86_64
Kernel: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08)
Release: Debian GNU/Linux 8 (jessie)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/hornaus/core (2016-05-12 15:59:27.103767942 +0200)
[New LWP 29054]
[New LWP 29057]
[New LWP 29056]
[New LWP 29058]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/x86_64-linux-gnu/kodi/kodi.bin --standalone'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000000000fd8078 in std::_Rb_tree<int, std::pair<int const, RssSet>, std::_Select1st<std::pair<int const, RssSet> >, std::less<int>, std::allocator<std::pair<int const, RssSet> > >::_M_erase(std::_Rb_tree_node<std::pair<int const, RssSet> >*) ()
Thread 4 (Thread 0x7efebffff700 (LWP 29058)):
#0 0x00007efee48e3d3d in poll () at ../sysdeps/unix/syscall-template.S:81
#1 0x00007efee95cad26 in ?? () from /usr/lib/x86_64-linux-gnu/libasound.so.2
#2 0x00007efee95cf0ce in ?? () from /usr/lib/x86_64-linux-gnu/libasound.so.2
#3 0x00007efee95dc45b in ?? () from /usr/lib/x86_64-linux-gnu/libasound.so.2
#4 0x00000000009a3acf in CAESinkALSA::AddPackets(unsigned char**, unsigned int, unsigned int) ()
#5 0x000000000098f6f6 in ActiveAE::CActiveAESink::OutputSamples(ActiveAE::CSampleBuffer*) ()
#6 0x00000000009909e1 in ActiveAE::CActiveAESink::StateMachine(int, Actor:rotocol*, Actor::Message*) ()
#7 0x0000000000991447 in ActiveAE::CActiveAESink:rocess() ()
#8 0x00000000012582ff in CThread::Action() ()
#9 0x00000000012585b9 in CThread:taticThread(void*) ()
#10 0x00007efeed0870a4 in start_thread (arg=0x7efebffff700) at pthread_create.c:309
#11 0x00007efee48ec87d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 3 (Thread 0x7efec5637700 (LWP 29056)):
#1 0x0000000000f31701 in CFDEventMonitor:rocess() ()
#2 0x00000000012582ff in CThread::Action() ()
#3 0x00000000012585b9 in CThread:taticThread(void*) ()
#4 0x00007efeed0870a4 in start_thread (arg=0x7efec5637700) at pthread_create.c:309
#5 0x00007efee48ec87d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 2 (Thread 0x7efec4817700 (LWP 29057)):
#0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238
#1 0x000000000098b703 in ActiveAE::CActiveAE:rocess() ()
#4 0x00007efeed0870a4 in start_thread (arg=0x7efec4817700) at pthread_create.c:309
Thread 1 (Thread 0x7efeef7598c0 (LWP 29054)):
#1 0x0000000000fd7259 in CRssManager::Clear() ()
#2 0x0000000000d22671 in CSettingsManager::OnSettingsUnloaded() ()
#3 0x0000000000d2335c in CSettingsManager::Unload() ()
#4 0x0000000000d26ee6 in CSettingsManager::Clear() ()
#5 0x00000000007019ba in CSettings::Uninitialize() ()
#6 0x000000000070248f in CSettings::~CSettings() ()
#7 0x00007efee483bb29 in __run_exit_handlers (status=-1, listp=0x7efee4ba95a8 <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true) at exit.c:82
#8 0x00007efee483bb75 in __GI_exit (status=<optimized out>) at exit.c:104
#9 0x00007efee4825b4c in __libc_start_main (main=0x6a6370 <main>, argc=2, argv=0x7ffcfc23c398, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7ffcfc23c388) at libc-start.c:321
#10 0x00000000006e72f9 in _start ()
############# END STACK TRACE ###############
################# LOG FILE ##################
15:59:26 T:139633404254400 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:59:26 T:139633404254400 NOTICE: -----------------------------------------------------------------------
15:59:26 T:139633404254400 NOTICE: Starting Kodi from Debian (15.2 Git: (unknown)). Platform: Linux x86 64-bit
15:59:26 T:139633404254400 NOTICE: Using Debug Kodi from Debian x64 build
15:59:26 T:139633404254400 NOTICE: Kodi from Debian compiled from 15.2+dfsg1-1~bpo8+1 by GCC 4.9.2 for Linux x86 64-bit version 3.16.7 (200711)
15:59:26 T:139633404254400 NOTICE: Running on Debian GNU/Linux 8 (jessie), kernel: Linux x86 64-bit version 3.16.0-4-amd64
15:59:26 T:139633404254400 NOTICE: FFmpeg version: 2.8.3-1~bpo8+1
15:59:26 T:139633404254400 NOTICE: Host CPU: Intel® Pentium® CPU G4400 @ 3.30GHz, 2 cores available
15:59:26 T:139633404254400 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:59:26 T:139633404254400 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi
15:59:26 T:139633404254400 NOTICE: special://masterprofile/ is mapped to: /root/.kodi/userdata
15:59:26 T:139633404254400 NOTICE: special://home/ is mapped to: /root/.kodi
15:59:26 T:139633404254400 NOTICE: special://temp/ is mapped to: /root/.kodi/temp
15:59:26 T:139633404254400 NOTICE: The executable running is: /usr/lib/x86_64-linux-gnu/kodi/kodi.bin
15:59:26 T:139633404254400 NOTICE: Local hostname: ls1
15:59:26 T:139633404254400 NOTICE: Log File is located: /root/.kodi/temp/kodi.log
15:59:26 T:139633404254400 DEBUG: ConsoleKit.Manager: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.ConsoleKit was not provided by any .service files
15:59:26 T:139633404254400 DEBUG: UPower: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
15:59:26 T:139633404254400 DEBUG: DeviceKit.Power: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
15:59:26 T:139633404254400 INFO: Selected Logind/UPower as PowerSyscall
15:59:26 T:139633404254400 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
15:59:26 T:139633404254400 INFO: LogindUPowerSyscall - UPower not found, battery information will not be available
15:59:26 T:139633404254400 DEBUG: LogindUPowerSyscall - inhibit lock taken, fd 11
15:59:26 T:139633404254400 NOTICE: load settings...
15:59:26 T:139633404254400 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
15:59:26 T:139633404254400 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/linux.xml
15:59:26 T:139633404254400 ERROR: PulseAudio: Failed to connect context
15:59:26 T:139633404254400 NOTICE: PulseAudio might not be running. Context was not created.
15:59:26 T:139632698423040 NOTICE: Thread FDEventMonitor start, auto delete: false
15:59:26 T:139633404254400 DEBUG: CAESinkALSA - HDMI device "hdmi:CARD=PCH,DEV=0" may be unconnected (no ELD data)
15:59:26 T:139633404254400 NOTICE: Found 1 Lists of Devices
15:59:26 T:139633404254400 NOTICE: Enumerated ALSA devices:
15:59:26 T:139633404254400 NOTICE: Device 1
15:59:26 T:139633404254400 NOTICE: m_deviceName : @
15:59:26 T:139633404254400 NOTICE: m_displayName : Default (HDA Intel PCH ALC1150 Analog)
15:59:26 T:139633404254400 NOTICE: m_displayNameExtra:
15:59:26 T:139633404254400 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:59:26 T:139633404254400 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
15:59:26 T:139633404254400 NOTICE: m_sampleRates : 48000
15:59:26 T:139633404254400 NOTICE: m_dataFormats : AE_FMT_S32NE
15:59:26 T:139633404254400 NOTICE: Device 2
15:59:26 T:139633404254400 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
15:59:26 T:139633404254400 NOTICE: m_displayName : HDA Intel PCH (@:CARD=PCH,DEV=0)
15:59:26 T:139633404254400 NOTICE: m_displayNameExtra: ALC1150 Analog
15:59:26 T:139633404254400 NOTICE: Device 3
15:59:26 T:139633404254400 NOTICE: m_deviceName : surround21:CARD=PCH,DEV=0
15:59:26 T:139633404254400 NOTICE: m_displayName : HDA Intel PCH (surround21:CARD=PCH,DEV=0)
15:59:26 T:139633404254400 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
15:59:26 T:139633404254400 NOTICE: m_sampleRates : 44100,48000,96000,192000
15:59:26 T:139633404254400 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
15:59:26 T:139633404254400 NOTICE: Device 4
15:59:26 T:139633404254400 NOTICE: m_deviceName : iec958:CARD=PCH,DEV=0
15:59:26 T:139633404254400 NOTICE: m_displayNameExtra: ALC1150 Digital S/PDIF
15:59:26 T:139633404254400 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
15:59:26 T:139633404254400 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,192000
15:59:26 T:139633404254400 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
15:59:26 T:139633404254400 NOTICE: Device 5
15:59:26 T:139633404254400 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
15:59:26 T:139633404254400 NOTICE: m_displayNameExtra: HDMI
15:59:26 T:139633404254400 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:59:26 T:139633404254400 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
15:59:26 T:139633404254400 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
15:59:26 T:139633404254400 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
15:59:26 T:139633404254400 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:59:26 T:139633404254400 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:59:26 T:139633404254400 NOTICE: Default DVD Player: dvdplayer
15:59:26 T:139633404254400 NOTICE: Default Video Player: dvdplayer
15:59:26 T:139633404254400 NOTICE: Default Audio Player: paplayer
15:59:26 T:139633404254400 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:59:26 T:139633404254400 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:59:26 T:139633404254400 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:59:26 T:139633404254400 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
15:59:26 T:139633404254400 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
15:59:26 T:139633404254400 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
15:59:26 T:139633404254400 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
15:59:26 T:139633404254400 NOTICE: Loaded playercorefactory configuration
15:59:26 T:139633404254400 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:59:26 T:139633404254400 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:59:26 T:139633404254400 INFO: creating subdirectories
15:59:26 T:139633404254400 INFO: userdata folder: special://masterprofile/
15:59:26 T:139633404254400 INFO: recording folder:
15:59:26 T:139633404254400 INFO: screenshots folder:
15:59:26 T:139632683611904 NOTICE: Thread ActiveAE start, auto delete: false
15:59:26 T:139632608016128 NOTICE: Thread AESink start, auto delete: false
15:59:27 T:139632608016128 INFO: CActiveAESink::OpenSink - initialize sink
15:59:27 T:139632608016128 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:@
15:59:27 T:139632608016128 INFO: CAESinkALSA::Initialize - Attempting to open device "@"
15:59:27 T:139632608016128 INFO: CAESinkALSA::Initialize - Opened device "sysdefault"
15:59:27 T:139632608016128 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
15:59:27 T:139632608016128 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
15:59:27 T:139632608016128 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 1024, bufferSize 8192
15:59:27 T:139632608016128 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 1024, bufferSize 8192
15:59:27 T:139632608016128 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 171 ms
15:59:27 T:139632608016128 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
15:59:27 T:139632608016128 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR
15:59:27 T:139632608016128 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: FL FR)
15:59:27 T:139632608016128 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
15:59:27 T:139632608016128 DEBUG: Output Device : Default (HDA Intel PCH ALC1150 Analog)
15:59:27 T:139632608016128 DEBUG: Sample Rate : 48000
15:59:27 T:139632608016128 DEBUG: Sample Format : AE_FMT_S32NE
15:59:27 T:139632608016128 DEBUG: Channel Count : 2
15:59:27 T:139632608016128 DEBUG: Channel Layout: FL,FR
15:59:27 T:139632608016128 DEBUG: Frames : 1024
15:59:27 T:139632608016128 DEBUG: Frame Samples : 2048
15:59:27 T:139632608016128 DEBUG: Frame Size : 8
15:59:27 T:139633404254400 NOTICE: Running database version Addons19
15:59:27 T:139633404254400 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-x86_64-linux.so)
15:59:27 T:139633404254400 DEBUG: Loading: /usr/lib/x86_64-linux-gnu/kodi/system/libcpluff-x86_64-linux.so
15:59:27 T:139633404254400 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/x86_64-linux-gnu/kodi/addons: No such file or directory'
15:59:27 T:139633404254400 NOTICE: ADDONS: Using repository repository.xbmc.org
15:59:27 T:139632597444352 NOTICE: Thread RemoteControl start, auto delete: false
15:59:27 T:139632597444352 INFO: LIRC Process: using: /dev/lircd
15:59:27 T:139632597444352 INFO: LIRC Connect: connect failed: No such file or directory
15:59:27 T:139632597444352 INFO: CRemoteControl:rocess - failed to connect to LIRC, will keep retrying every 5 seconds
15:59:27 T:139633404254400 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
15:59:27 T:139633404254400 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
15:59:27 T:139633404254400 DEBUG: UDisks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UDisks was not provided by any .service files
15:59:27 T:139633404254400 DEBUG: DeviceKit.Disks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
15:59:27 T:139633404254400 DEBUG: Selected UDev as storage provider
15:59:27 T:139633404254400 NOTICE: Setup SDL
15:59:27 T:139633404254400 ERROR: GLX Error: No Display found
15:59:27 T:139633404254400 FATAL: CApplication::Create: Unable to init windowing system
15:59:27 T:139633404254400 DEBUG: PVRManager - destroyed
15:59:27 T:139632597444352 DEBUG: Failed to connect to LIRC. Giving up.
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
br
Pat
CLI
LOG ITSELF
Kodi Options:
Arch: x86_64
[New LWP 29054]
[New LWP 29057]
[New LWP 29056]
[New LWP 29058]
br
Pat
