On one of my pc recently when I open a movie I only get audio and the video keeps changing colour but no picture just goes like red, blue ..... According to the picture. It was working good I even downgraded and no help I completely removed Lodi and started fresh and same problem. Could it be something changed with the update. Also it's working on all my other systems. And it's a old vaio I have it running on connected to my tv. Help me please.
Try to disable DXVA2 under system/settings/video/acceleration.
Keep in mind that your Vaio might not be DX11 compliant.
Either way a
debug log (wiki) might get you more help.
So if it's not DX11 compliant then I should downgrade again?
Version 15 does not require DX11 so it is worth a try.
I would say yes.
By chance what version 15 should I go with ?any version
(2016-05-13, 12:54)iarmd1 Wrote: [ -> ]By chance what version 15 should I go with ?any version
15.2 was the last stable for Isengard, if you want to give Jarvis a look see you could install it in portable mode on a USB key and then copy your meta-data over to it and see if it works for you.
I have Jarvis on another pc and it works just fine it's just the one on after the upgrade
