I've created a smart playlist with cartoons for my kids and a smart playlist with regular movies.
In the home screen customization, how do I tell a menu point to hit the playlist, instead of normal movies?
I can't seem to find anyway to select a playlist in the customization. Should I use a custom action? If so, what should I put into it?
Smart Playlists should be inside "Video Library" -> "Playlist"
Tgx
(2016-05-13, 12:30)Tgxcorporation Wrote: [ -> ]Smart Playlists should be inside "Video Library" -> "Playlist"
Tgx
This seems to just give me an action to open the list of playlists instead of a specific one.
Am I doing something wrong? Did I miss something?
Enter your playlist and click "create shortcut from here" or something similar.
Tgx
(2016-05-13, 13:22)Tgxcorporation Wrote: [ -> ]Enter your playlist and click "create shortcut from here" or something similar.
Tgx
I'm probably completely clueless, but how do you mean "enter your playlist"?
If I just goto videos->playlists->kids (playlist is called kids) I get the list of items in the playlist. I can't seem to make any shortcuts.
(2016-05-13, 13:51)Tgxcorporation Wrote: [ -> ]You have to use the home menu editor.
This is the skin wiki: https://github.com/Tgxcorporation/skin.nebula/wiki
Tgx
Yea I did use that.
I ended up getting it to work. I'm not sure if there's an easier way, but I put a custom action in, that looked like this: ActivateWindow(Videos,special://videoplaylists/kids.xsp,return)
see my thread on this. Tgx explained exactly how to do it.
I have exactly the same problem with AEON NOX SiLVO v9.0.1
After creating a smart playlist and choose an entry for main MenĂ¼, my new created smart playlist is not listed under the playlists!!
Tried many times, deleted and recreated playlists...
Did it many times before, but now the smart playlist es are simply not listed for the menue entry.
(2023-06-12, 15:33)Kamikaze01 Wrote: [ -> ]I have exactly the same problem with AEON NOX SiLVO v9.0.1
if you are having the same problem as someone from 2016 that would be incredible or you havent updated since 2016
why would you report your issue to the
Nebula skin support section when you are using AEON NOX SiLVO v9.0.1?
try reporting it to the correct place if you want help -
https://forum.kodi.tv/forumdisplay.php?fid=142
