Full Version: Pluto Home Automation Control Component for XBMC?
Hello,
I would like to clarify and resubmit an idea that was posted a while back. I think that it was misunderstood and, if done properly, it can be a great addition to XBMC and a step towards future integration with home automation components.
The Post can be found here:
http://forum.xbmc.org/showthread.php?tid=13945
However there are a few things that need clarifying. The xbox would not act as a hub that would require wiring and serial ports to control lights/heating & AC/security The xbox would simply act as a terminal through the network. The Pluto Home Automation system is built around a central server that is programmed and wired to handle all those devices. The xbox would serve as a media director, mainly used for streaming media to a TV or to speakers.
If you still dont quite grasp the usefulness of this system you can check out the flash presentation here:
http://plutohome.com/presentation.html
Anyways I would like some feedback about this. Pluto has completely open source code so if the netboot option will not work, an option could be trying to add modules into XBMC to work with system! Yay for high tech stuff Big Grin
Since there are several home-automations systems protocols and not really just one standard this should not be implemented into XBMC nativly (in hard-coded C++ code), instead if home-automation system controls will be added to XBMC then it should be via python script(s). Thus I am moving this topic-thread (and the discussion) to the python suggestions forum.
Also see these related topics:
* HomeControl script v1.5 : Homeseer / X10
* Wanted!: Script writer for xAP protocol
* X-10 Script
PS! Googling "pluto home automation python" brings out a few interesting resources o the topic:
http://www.linuxjournal.com/article/8513
http://qkits.com/
http://home.comcast.net/~ncherry/
Scripters should of course also checkout the wiki manual on python scripting:
http://www.xboxmediacenter.com/wiki/inde...on_Scripts
http://www.xboxmediacenter.com/wiki/inde...ory:Python
http://www.xboxmediacenter.com/wiki/inde...n_Tutorial
