Full Version: Rename Addon Browser folder name in core
Not sure where the folder names are defined in core, but wouldn't it make more sense for this folder name to be "Addon Browser" or something similar? Instead of "Install from repository", which is just one of the items. Thanks for considering.
Edit: Also noticed that the window name "musicinformation" still seems to point to DialogAlbumInfo.xml, which no longer exists. Should point to DialogMusicInfo.xml.
I pull request : 9819 (PR)
For "musicinformation" where do you see that ?
Skin debugging -
I haven't been able to get Window.IsVisible(musicinformation) to work. Instead, I've been using Window.IsVisible(DialogMusicInfo.xml). Will test again with the latest nightly.
My pull request have been merged Wink
Thanks Guilouz!
(2016-05-16, 19:08)braz Wrote: [ -> ]I haven't been able to get Window.IsVisible(musicinformation) to work. Instead, I've been using Window.IsVisible(DialogMusicInfo.xml). Will test again with the latest nightly.
Just tested again, Window.IsVisible(musicinformation) does not work in the latest nightlies. Window.IsVisible(DialogMusicInfo.xml) is my workaround for now...
(2016-05-24, 02:20)braz Wrote: [ -> ]Just tested again, Window.IsVisible(musicinformation) does not work in the latest nightlies.
can't reproduce, works fine on my end
(2016-05-26, 16:03)ronie Wrote: [ -> ]
Thanks, I can confirm it's working for me now too.
