2016-09-17, 21:21
(2016-09-14, 23:37)MetalChris Wrote: [ -> ]I'll look into adding an abort command and see if that will kill the timer if the stream is stopped.
Having given this a little more thought, I think I see what is actually happening here. The add-on checks the state of xbmc.Player, and if the player is playing (anything) it scrapes the song info, displays the notification, and then starts a timer to control when the notification is displayed again. The timer would run for 60 seconds. If you stop the stream, the timer would continue running until the 60 seconds were up, it would then display the notification, and then check the state of xbmc.Player again. As long as the player was playing anything, the add-on did not care if you were still playing the Buddha stream, or if you had started playing something else. So if you stopped the Buddha stream and then started playing a video or another audio stream before the timer had run out, the notification would continue to display every 60 seconds. So I've changed the way the timer runs. Instead of running for 60 seconds, the timer will run for 1 second inside a loop that repeats 60 times. In this way, the add-on will check the state of xmbc.Player every second. If you happen to be fast enough to stop the Buddha stream, and then start playing a video or another audio stream all within 1 second, the notification will continue to display every 60 seconds. I don't think most people will be able to do this, so version 1.0.3 should solve the issue of the notification continuing after the Buddha stream has been stopped.
Give it a try and see if this works for you. I believe I could actually set the timer to run in fractions of a second, but I do not think that will be necessary.
Buddha Radio v - 1.0.3
(2016-09-15, 08:04)peppe_sr Wrote: [ -> ]thanks, really appreciated.
could i do a "cosmetic" request? during the reproduction of music instead of "playlist" could be displayed the name of the station?
thanks again.
Peppe
Yep, this bugs me too. I've tried a couple of ways to get the add-on to display 'Buddha Radio' instead of 'playlist.m3u8', but it seems Kodi overrides each method I've tried. I'll keep trying, and hopefully I'll figure it out soon.
