2016-05-14, 19:46
Kodi is acting up on a fire stick that I bought that it was pre installed on . Is there an easy way to reset it to default ...or is it easy to take it off and reinstall it on the fire stick . Please help thanks
(2016-05-15, 00:36)Doublecheck456 Wrote: [ -> ]I thought clearing data cleared Kodi off of the fire stick does it only just reset Kodi to default is that all that does
(2016-05-15, 17:13)Dangelus Wrote: [ -> ]Why start another thread when you have a perfectly good one here where you are asking the same thing?So I don't think that is what you are wanting to do if you got your fire tv stick with a kodi build already on it because you will lose all the apps that have been installed in kodi which gives access to the movie content you're probably trying to get. This will basically wipe kodi clean but kodi comes with zero content, it is just a media server software.
http://forum.kodi.tv/showthread.php?tid=274237
The answer once again is YES, clearing data will remove everything and leave you with a clean installation of default Kodi.
Merging threads.
