Full Version: an unusual problem for Kodi user:-) screen time out in Kodibuntu
hello, the reason my title says unusual problem is that if you only use the Kodi UI all is fine
but at the moment I need to use a real browser to play some movies and what happens is the screen blanks out after several minutes.
one sec all is ok next no signal. my tv screen is blue.
hit a space bar or scratch a finger on touch-pad and all is back. and continues.
when I am in Kodi UI this does not happens
I had turned off the power-management with "xset" but that did not worked.
any other thing I can try?
can I turn off this permanently?
thanks VL
PS: I should be running Kodi 16.0. not sure at the moment as I haven't updated in month.
custom build HTPC
