Hi all, I have Flirc USB receiver with Win7 and running Jarvis 16. I was reading about the keymap.xml file modifications but can't seem to find anything about how to map the Favorites (star icon) to my Flirc and/or to my universal remote. Can someone please help me out or point me in the right direction?
You need to map a key to XBMC.ActivateWindow(Favourites)
EG
PHP Code:
<keymap>
<global>
<keyboard>
<keyname>XBMC.ActivateWindow(Favourites)</keyname>
</keyboard>
</global>
</keymap>
(2016-05-16, 21:56)black_eagle Wrote: [ -> ]You need to map a key to XBMC.ActivateWindow(Favourites)
EG
PHP Code:
<keymap>
<global>
<keyboard>
</keyboard>
</global>
</keymap>
Thanks for the quick reply. I found this in another thread where I think 61510 is the "f" key. Is the below also correct? I guess the reason im asking is that your example above doesn't have key id tags. (sorry not much of an xml'er). Thanks.
<keymap><global><keyboard><key id="61510">activatewindow(favourites)</key></keyboard></global></keymap>
(2016-05-16, 22:14)nealsil Wrote: [ -> ]Thanks for the quick reply. I found this in another thread where I think 61510 is the "f" key. Is the below also correct? I guess the reason im asking is that your example above doesn't have key id tags. (sorry not much of an xml'er). Thanks.
If that is indeed the key ID then almost
<key id="61510">
XBMC.ActivateWindow(favourites)</key>
Etc
Thanks. So then the whole thing would look like this:?
<keymap>
<global>
<keyboard>
<key id="61510">XBMC.ActivateWindow(favourites)</key>
</keyboard>
</global>
</keymap>
Yes. See
keymap (wiki) for more info if you need it.
Thanks a million for the help. I'll try it tonight!
