Full Version: Kodi Display errors on LG UH7700 4k TV
SO I just got this nice 4k tv...its purty
I hook up my HTPC with the latest version of KODI on it and low and behold.
1. either the image is SO big that I get about 20% of the upper left portion of KODI
2. or I have to make it windowed and fit it to the screen..
that's it. I check the resolution settings and its the same as what is on the video card.
I have the ZOTAC GeForce GTX 950 2GB 128-Bit GDDR5 in the HTPC , the highest setting is 3840 x 2160, both the card and KODI are set to this
if i change it, its still either too large or too small, small where its only half the screen and scrunched.
has anyone had this issue?
Windows 10?
I use also a GTX 950 video card and the LG 60UF675V 4K TV.
No problem.
But look in Windows 10 for "screen settings" (right click on desktop) !
Go to the property "size text, apps, ..." .
The slider must be at the most left side.
It happens also to me sometimes the slider is positioned far more at the right side and everything (text,images,...) becomes very big.
The Kodi OSD can't handle it.
