Full Version: crash
Hello,
I have often crash on the system.
Is any body can help me ?
Many thanks for your help.
Thierry
23:57:23 T:140496064891200 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:57:23 T:140496064891200 NOTICE: -----------------------------------------------------------------------
23:57:23 T:140496064891200 NOTICE: Starting Kodi (16.0 Git:a5f3a99). Platform: Linux x86 64-bit
23:57:23 T:140496064891200 NOTICE: Using Release Kodi x64 build
23:57:23 T:140496064891200 NOTICE: Kodi compiled Feb 20 2016 by GCC 5.2.1 for Linux x86 64-bit version 4.2.8 (262664)
23:57:23 T:140496064891200 NOTICE: Running on Ubuntu 16.04 LTS, kernel: Linux x86 64-bit version 4.4.0-22-generic
23:57:23 T:140496064891200 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
23:57:23 T:140496064891200 NOTICE: Host CPU: Intel® Core™ i5-3317U CPU @ 1.70GHz, 4 cores available
23:57:23 T:140496064891200 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
23:57:23 T:140496064891200 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
23:57:23 T:140496064891200 NOTICE: special://masterprofile/ is mapped to: /home/vorms/.kodi/userdata
23:57:23 T:140496064891200 NOTICE: special://home/ is mapped to: /home/vorms/.kodi
23:57:23 T:140496064891200 NOTICE: special://temp/ is mapped to: /home/vorms/.kodi/temp
23:57:23 T:140496064891200 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
23:57:23 T:140496064891200 NOTICE: Local hostname: NUK
23:57:23 T:140496064891200 NOTICE: Log File is located: /home/vorms/.kodi/temp/kodi.log
23:57:23 T:140496064891200 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - La propriété « CanSuspend » n'existe pas
23:57:23 T:140496064891200 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - La propriété « CanHibernate » n'existe pas
23:57:23 T:140496064891200 NOTICE: load settings...
23:57:23 T:140496064891200 NOTICE: Found 1 Lists of Devices
23:57:23 T:140496064891200 NOTICE: Enumerated PULSE devices:
23:57:23 T:140496064891200 NOTICE: Device 1
23:57:23 T:140496064891200 NOTICE: m_deviceName : Default
23:57:23 T:140496064891200 NOTICE: m_displayName : Default
23:57:23 T:140496064891200 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
23:57:23 T:140496064891200 NOTICE: m_deviceType : AE_DEVTYPE_PCM
23:57:23 T:140496064891200 NOTICE: m_channels : FL,FR
23:57:23 T:140496064891200 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,17$
23:57:23 T:140496064891200 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE$
23:57:23 T:140496064891200 NOTICE: Device 2
23:57:23 T:140496064891200 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.hdmi-stereo
23:57:23 T:140496064891200 NOTICE: m_displayName : Audio interne Digital Stereo (HDMI)
23:57:23 T:140496064891200 NOTICE: m_displayNameExtra: HDMI / DisplayPort (PULSEAUDIO)
23:57:23 T:140496064891200 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
23:57:23 T:140496064891200 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
23:57:23 T:140496064891200 NOTICE: Default DVD Player: dvdplayer
23:57:23 T:140496064891200 NOTICE: Default Video Player: dvdplayer
23:57:23 T:140496064891200 NOTICE: Default Audio Player: paplayer
23:57:23 T:140496064891200 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:57:23 T:140496064891200 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
23:57:23 T:140496064891200 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
23:57:23 T:140496064891200 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:57:23 T:140496064891200 NOTICE: Loaded playercorefactory configuration
23:57:23 T:140496064891200 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:57:23 T:140496064891200 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:57:23 T:140495574001408 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
23:57:23 T:140496064891200 NOTICE: Running database version Addons20
23:57:23 T:140496064891200 NOTICE: ADDONS: Using repository repository.xbmc.org
23:57:23 T:140496064891200 NOTICE: ADDONS: Using repository repository.vstream
23:57:23 T:140496064891200 NOTICE: Setup SDL
23:57:23 T:140496064891200 NOTICE: Checking resolution 16
23:57:23 T:140496064891200 NOTICE: Using visual 0x20
23:57:23 T:140496064891200 NOTICE: GL_VENDOR = Intel Open Source Technology Center
23:57:23 T:140496064891200 NOTICE: GL_RENDERER = Mesa DRI Intel® Ivybridge Mobile
23:57:23 T:140496064891200 NOTICE: GL_VERSION = 3.0 Mesa 11.2.0
23:57:23 T:140496064891200 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
23:57:23 T:140496064891200 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_min$
23:57:24 T:140496064891200 NOTICE: Running database version Addons20
23:57:24 T:140496064891200 NOTICE: Running database version ViewModes6
23:57:24 T:140496064891200 NOTICE: Running database version Textures13
23:57:24 T:140496064891200 NOTICE: Running database version MyMusic56
23:57:24 T:140496064891200 NOTICE: Running database version MyVideos99
23:57:24 T:140496064891200 NOTICE: Running database version TV29
23:57:24 T:140496064891200 NOTICE: Running database version Epg11
23:57:24 T:140496064891200 NOTICE: start dvd mediatype detection
23:57:24 T:140496064891200 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
23:57:24 T:140496064891200 NOTICE: ActiveAE DSP - starting
23:57:24 T:140496064891200 NOTICE: UpdateLibraries: Starting music library startup scan
23:57:24 T:140494864631552 NOTICE: PVRManager - starting up
23:57:24 T:140494545872640 NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 154 channels.
23:57:24 T:140496064891200 NOTICE: initialize done
23:57:24 T:140496064891200 NOTICE: Running the application...
23:57:24 T:140496064891200 NOTICE: starting zeroconf publishing
23:57:24 T:140496064891200 ERROR: WebServer: Failed to start the webserver
23:57:24 T:140496064891200 NOTICE: starting upnp client
23:57:24 T:140496064891200 NOTICE: starting upnp server
23:57:24 T:140496064891200 NOTICE: starting upnp controller
23:57:24 T:140496064891200 NOTICE: starting upnp renderer
23:57:24 T:140493706995456 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
23:57:24 T:140493706995456 NOTICE: UDP: Listening on port 9777
23:57:24 T:140496064891200 ERROR: Failed to start AirTunes Server
23:57:24 T:140496064891200 ERROR: AIRPLAY Server: Failed to bind ipv4 serversocket
23:57:25 T:140494864631552 NOTICE: Start - EPG thread started
23:57:25 T:140492851365632 ERROR: AddOnLog: PVR IPTV Simple Client: Unable to load EPG file '/tmp/tvguide.xml': file is missing$
23:57:25 T:140494873024256 NOTICE: FORUMBROWSER-SERVICE: STARTED :: Enabled: False - Start Only: False - Interval: 1200s
23:57:26 T:140493748958976 ERROR: Traceback (most recent call last):
23:57:26 T:140493748958976 ERROR: File "/home/vorms/.kodi/addons/script.tvguide/source.py", line 346, in _updateChannelAndProg$
23:57:26 T:140493748958976 ERROR: for item in self.source.getDataFromExternal(date, progress_callback):
23:57:26 T:140493748958976 ERROR: File "/home/vorms/.kodi/addons/script.tvguide/source.py", line 818, in getDataFromExternal
Quote:23:57:25 T:140492851365632 ERROR: AddOnLog: PVR IPTV Simple Client: Unable to load EPG file '/tmp/tvguide.xml': file is missing$
Remove your broken addonsm please.
