I am looking at Hubpixed - the connectorless 4 port USB hub for Pi Zero. I am impressed by its potentially novel solution. Can you tell me where I can buy it?
You may want to check at ebay and amazon for Hubpixed.
On the sidenote - Have you also checked HubPiWi - it integrates a Hub and a Wifi and does not need any cable or connector. It is currently on kickstarter.
For the original Hubpixed, click
here for the makers website purchase page.
But as @
digger72 says, they've got a Kickstarter on the go at the moment for something similar with built-in wifi (
here) which is about 50% funded at the moment.
The HubPiWi bidding has ended at kickstarter. It is a nice Hub with integrated Wifi - the good thing is that it is designed to work with the newer P1 Zero 1.3 version ( and there is also a version to work with earlier 1.2). The HubPiwi is available at referencedesigner site.
