(2017-04-04, 16:37)BORIStheBLADE Wrote: [ -> ]Quick question for the people using the USB to ethernet adapter. Are you having any issues playing a Blu-ray rip with HD audio? Is it consistent?
Are all USB to ethernet adapters the same?
I rarely use my MiBox, but just ran a test using my Avatar BlueRay rip, playing with the latest version of SPMC . I have this USB Ethernet adapter (Plugable USB 3.0 to 10/100/1000 Gigabit Ethernet LAN Network Adapter (ASIX AX88179 chipset,), and the movie is playing perfectly with HD audio. My Denon AVR is showing "DTS-HD MA"
Avatar media info:
Format : Matroska
Format version : Version 2
File size : 39.7 GiB
Duration : 2 h 41 min
Overall bit rate : 35.2 Mb/s
Movie name : Avatar
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=24
Codec ID : V_MPEG4/ISO/AVC
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : No
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Bit rate mode : Variable / Constant
Bit rate : Unknown / 1 509 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Delay relative to video : 2 ms
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
