2016-05-21, 15:53
Hello, I would like to call a second plugin from a plugin. To realice the call I use XBMC.Container.Update(). The problem appear if I use the ".." button (back button) to change from the second plugin back to the first plugin. Then kodi changes to "plugin://plugin.first/?mode=call_plugin" instead of "plugin://plugin.first/". The mode "call_plugin" calls the second plugin again and it's not possible to get back to the first plugin.
I could be able to solve the problem if it is possible to read the kodi path history in python. Than I could ignore the plugin call if the last history item is equal with "plugin://plugin.first/?mode=call_plugin".
Is it possible to read the path history in python or is there another way to solve the problem? Thanks
