Full Version: 100% CPU load on one CPU core with Nvidia GPU
Hello FernetMenta,
would you please have a look at 2341229 (post).
Kodi is causing a 100% CPU load on one core, this results in massive frame dropping especially with 25fps stuff.
Milhouse already worked out the changes, they likely cause this behaviour.
Systems with Intel GPUs are not affected, seems to be a Nvidia only issue.
Thank you!
Thank NVidia for their crappy drivers. Start Kodi like this:
__GL_YIELD=USLEEP kodi
Fixed,
Thank you!
Many thanks, works also for ION2. Will include in tonight's build.
