2016-05-24, 22:41
Lately, I've been experiencing an issue with some files. On XBMC 13.2: playback stops repeatedly while watching an episode of a show (accessed through samba), takes me back to the xbmc user interface and gives me a "connection timeout" dialog box. These episodes are around ~500mb each so I don't think it's because of caching. I also watch other HD shows and movies with sizes ranging between ~1.5GB and ~12GB respectively and the issue doesn't happen at all.
XBMC 13.2 log: http://xbmclogs.com/p0q4kn58h
During playback this happened around 16:28 with lines like this in the log:
The issue is a little different on Kodi 16.1: playback stops but it just buffers for a couple of seconds and then resumes playing. Buffering is unheard of on my setup even while playing the previously mentioned ~12GB (and bigger) mkvs. Below are the mediainfo of the file in question and the logs.
Kodi 16.1 log : http://xbmclogs.com/pckwiu7gj
In playback the trouble started around time 14:55, that has this kind of lines:
At first this seemed to only happened with the this season of the show in question, I tried downloading a different encode of the show (previous post was tested with one such encode) but the problem still persisted and now this also seems to be happening with other files from other (anime) shows. It seems that the issue is confined to this type of shows right now. It's very weird. I reencoded some of the files to 8bit in order to see if this was the issue but the problem persisted so whatever it is persists reencodes. I'm at my wits end here so any help would be appreciated. Let me know if anything else is needed to debug this.
I have attempted some fixes I found around the net, including changing some settings in smb.conf to no effect.
PS: I had posted about this before using a custom XBMC build that came with my TV box, this post is done after reproducing the issue on official builds.
mediainfo 'TroubledTvShow S03E23 (BD 1920x1080 x264 FLAC Eng.subs).mkv'
General
Unique ID : 173096219274832500578912549514400193351 (0x82391E83A3C124C995D55D79DE0F5B47)
Complete name : TroubledTvShow S03E23 (BD 1920x1080 x264 FLAC Eng.subs).mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 482 MiB
Duration : 24mn 32s
Overall bit rate mode : Variable
Overall bit rate : 2 747 Kbps
Movie name : TroubledTvShow III 23
Encoded date : UTC 2014-06-13 18:08:31
Writing application : mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Attachements : Sketched.ttf / steelfish rg.ttf / StoneHinge.ttf / TheGreatEscape.ttf / TheGreatEscapeBold.ttf / TRACE_.TTF / tt0102m.ttf / tt0102m_.ttf / where stars shine the brightest.ttf / [z] Arista.ttf / akarinop.ttf / ANA-ONEIROPARMENI82.TTF / A-OTF-TakaHandStd-Heavy-haganai.ttf / arnopro-smbdcaption.otf / ArnoPro-SmbdSmText.otf / ArnoPro-SmbdSubhead.otf / AurulentSans-Bold.otf / AurulentSans-Regular.otf / AVGARDNECLIPSE.TTF / Barmeno-Medium.otf / BenguiatITCbyBT-MediumCondensed.otf / Big_Bimbo_NC_Regular.ttf / BlissProOT-Regular.otf / Candara.ttf / Candarab.ttf / CartoGothicStd-Book.otf / CENTURYO.TTF / Cicle Semi.ttf / Clannad_Round_Regular.ttf / Comfortaa-Bold.ttf / coolvetica rg.ttf / corbelb.ttf / COUTURE-Bold.ttf / CronosPro-Disp.otf / Danger Diabolik.ttf / DejaVuSans.ttf / Elegance.TTF / ERASBD.TTF / ERASDEMI.TTF / estre.ttf / HannaHandwriting.ttf / HighlanderStd-Medium.otf / Jennifers Hand Writing.ttf / kalingab.ttf / KGTurningTables.ttf / LBRITED.TTF / LightWrite_Normal.ttf / Linotype_Ordinar_Regular.ttf / LT_CorinthianMedium.ttf / mentone-semibol.otf / mentone-semibold.otf / MorningStress-Regular.ttf / ODENB_.TTF / posthuman.ttf / PTS75F.ttf / PTS76F.ttf / RolandBecker Bold.ttf / Schoolbell.ttf / shimano-squareblack.ttf / Sketchbook Nasty.otf
DURATION : 00:24:29.610000000
NUMBER_OF_FRAMES : 1821
NUMBER_OF_BYTES : 283752
_STATISTICS_WRITING_APP : mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27
_STATISTICS_WRITING_DATE_UTC : 2014-06-13 18:08:31
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 32s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Writing library : x264 core 133 r2334 a3ac64b
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=4 / psy=1 / psy_rd=0.60:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=18.4 / qcomp=0.60 / qpmin=10 / qpmax=38 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : Japanese
Default : No
Forced : No
DURATION : 00:24:32.013000000
NUMBER_OF_FRAMES : 35293
NUMBER_OF_BYTES : 377159321
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 24mn 32s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Default : Yes
Forced : No
Menu
00:00:00.033 : en:Intro
00:01:12.850 : en:OP
00:02:43.990 : en:Part A
00:11:25.860 : en:Part B
00:22:55.400 : en:ED
00:24:14.830 : en:Preview
16:27:46 T:1839186680 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
16:27:48 T:1811759040 ERROR: virtual unsigned int XFILE::CSmbFile::Read(void*, int64_t) - Error( -1, 110, Connection timed out )
16:27:48 T:1839186680 ERROR: Previous line repeats 2 times.
16:27:48 T:1839186680 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_EOF
16:27:48 T:1811759040 NOTICE: CDVDPlayer::OnExit()
mediainfo 'TroubledTvShow S3E22 (BD 1920x1080 x264 FLAC Eng.subs).mkv'
General
Unique ID : 217491343596691929372075187411577594723 (0xA39F4F22FFACA4B3B9B01F790199E363)
Complete name : TroubledTvShow S3E22 (BD 1920x1080 x264 FLAC Eng.subs).mkv
Format : Matroska
File size : 519 MiB
Duration : 24mn 40s
Overall bit rate : 2 941 Kbps
Movie name : TroubledTvShow III 22
Encoded date : UTC 2014-06-13 18:02:54
Attachements : AVGARDNECLIPSE.TTF / Barmeno-Medium.otf / BenguiatITCbyBT-MediumCondensed.otf / Big_Bimbo_NC_Regular.ttf / BlissProOT-Regular.otf / Candara.ttf / Candarab.ttf / CartoGothicStd-Book.otf / CENTURYO.TTF / Cicle Semi.ttf / Clannad_Round_Regular.ttf / Comfortaa-Bold.ttf / coolvetica rg.ttf / corbelb.ttf / COUTURE-Bold.ttf / CronosPro-Disp.otf / Danger Diabolik.ttf / DejaVuSans.ttf / HannaHandwriting.ttf / Jennifers Hand Writing.ttf / kalingab.ttf / LBRITED.TTF / Linotype_Ordinar_Regular.ttf / LT_CorinthianMedium.ttf / mentone-semibol.otf / mentone-semibold.otf / MorningStress-Regular.ttf / ODENB_.TTF / posthuman.ttf / PTS75F.ttf / PTS76F.ttf / RolandBecker Bold.ttf / Schoolbell.ttf / shimano-squareblack.ttf / Sketchbook Nasty.otf / Sketched.ttf / steelfish rg.ttf / StoneHinge.ttf / TheGreatEscape.ttf / TheGreatEscapeBold.ttf / TRACE_.TTF / tt0102m.ttf / tt0102m_.ttf / ANA-ONEIROPARMENI82.TTF / A-OTF-TakaHandStd-Heavy-haganai.ttf / arnopro-smbdcaption.otf / ArnoPro-SmbdSmText.otf
DURATION : 00:24:40.480000000
NUMBER_OF_FRAMES : 17350
NUMBER_OF_BYTES : 119388674
_STATISTICS_WRITING_DATE_UTC : 2014-06-13 18:02:54
Video
Format : AVC
Duration : 24mn 40s
Color space : YUV
Bit depth : 10 bits
Language : Japanese
Default : No
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 24mn 40s
Bit depth : 16 bits
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Default : Yes
Forced : No
DURATION : 00:24:40.479000000
NUMBER_OF_FRAMES : 35496
NUMBER_OF_BYTES : 417973805
Menu
00:00:23.250 : en:OP
00:01:52.450 : en:Part A
00:12:47.450 : en:Part B
00:22:55.730 : en:ED
00:24:15.290 : en:Preview
14:55:38 T:1849890144 ERROR: virtual ssize_t XFILE::CSMBFile::Read(void*, size_t) - Error( -1, 22, Invalid argument ) - Retrying
14:55:43 T:1852204768 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 85
14:55:43 T:1852204768 NOTICE: Previous line repeats 62 times.
14:55:43 T:1852204768 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 3 packets of duration 32
