I'd like to use some of the old pictures from Amber. There was a background with a picture of an old TV set on it.
Where can it be located?
You can try looking in the github history to find the background, use a url like the one below
https://github.com/jester-xbmc/skin.ambe...VShows.jpg
where the last part can be any of the background images from the backgrounds folder
e.g
This is the background I'm looking for, but can't see it in the github - I'm assuming it was part of Amber at some point ...
http://imgur.com/JyRUN3t
(2016-05-26, 11:58)joelbaby Wrote: [ -> ]This is the background I'm looking for, but can't see it in the github - I'm assuming it was part of Amber at some point ...
Sorry but I don't ever remember that one, maybe someone will be able to point you in the right direction.
