Full Version: WorldStarCandy
Hello folks,
I made a video addon for the adult softcore video site WorldStarCandy (http://www.worldstarcandy.com)
It will NOT be available as a video addon in the official kodi repo, instead you can download it here:
http://www.mediafire.com/file/zafcizb8fu5xzz1/plugin.video.worldstarcandy102.zip
You can install it as a video addon: http://kodi.wiki/view/HOW-TO:Install_add..._zip_files
If you got problems with the addon, just reply here with a link to a kodi log file (here are the instructions to make a logfile with kodi: http://kodi.wiki/view/Log_file/Easy ).
Enjoy.
v1.0.2 (2018-01-21)
- removed looking for video dialogue
- addon now works in kode python 2 and should also work in python 3 (!!) once all dependencies work in python 3.
Kudo's to the python future package for making this possible. Kudo's to RomanVM for the help.
v1.0.1 (2017-04-14):
- adjusted video detection to website changes
- fixed url in addon.xml as per request
- changed 'xbmc' to 'kodi' in some text
- not using addon-name in xbmcaddon.Addon() anymore (thanks enen92)
- using po-files
- changed addon debugging info to kodi debugging info
v1.0.0 (2016-05-26):
- initial version
- initial version
Thank you, works OK in Android box with Kodi 16.1
This addon Is not playing the videos. It's not finding the video sources. Can you please fix it? ThanksBig Grin
worldstarcandy seems broken, i will have a look.
- using po-files
Download it from here:
http://www.mediafire.com/file/7cidneup71e1xe7/plugin.video.worldstarcandy101.zip
Install it like this:
Thanks a bunch buddy, I will try the new update! This is my Friday motivation addon lolBig Grin
works great, thanks much
v1.0.2 (2018-01-21)
