2016-05-30, 18:40
Hello everybody.
Long, long time user of XBMC here.
Nowadays my (main) setup is as follows:
- OS X 10.8.5
- Mac Mini 2013 (I think). i7 2.3 GHz, 16 GB RAM.
- Connected via HDMI to a LG TV
- Kodi 16.1 installed from dmg
My problem appears when playing media in Kodi. VLC has not the same problem.
It started about a couple of months ago, but I have no exact date.
If I start playing a movie / TV show / video, after a while (it usually takes several minutes) the sound will skip for about one second. Then it will be fine for a few seconds (or minutes, it depends) and will skip again.
It happens with SD and HD videos, avi and mkv containers. If I go back and play the same segment again, sound will be fine.
If I check the logs, it seems that whenever the sound skips I get a message like this:
CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
I've googled it, but I haven't found how to solve the problem.
I've started a movie and let it play until the first skip happened. Here's the full log:
http://pastebin.com/d2wr6nUL
I'd be very grateful if someone could provide some insight.
Thanks in advance!
Notes:
- A reinstall of Kodi 16.1 on top of the current setup won't fix it.
- A reinstall from scratch won't fix it. It keeps me entertained for a while, 'though. Plugins, subtitles, keymaps....
- Playing the same video with other players (VLC) works every time.
- OS X 10.8.5
Thanks in advance!
Notes:
