well i have not got the stage where i XBMC is asking for data but it does not like my ts stream!
Playing
http://192.168.1.5:4097/8/video/mpeg/$03fd$0366.mpg.
09:03:29 M: 31842304 DEBUG: msg: find subtitles
09:03:29 M: 31842304 DEBUG: msg: auto open Z:\subtitle
09:03:29 M: 31842304 DEBUG: msg: Filename for url is now
09:03:29 M: 31842304 DEBUG: msg: protocol:http
09:03:29 M: 31842304 DEBUG: msg: open stream protocol:http
09:03:29 M: 31821824 DEBUG: msg: WINSOCK2 init: 0
09:03:29 M: 31821824 DEBUG: msg: Filename for url is now
09:03:29 M: 31821824 DEBUG: msg: Connecting to server 192.168.1.5[192.168.1.5]:4097 ...
09:03:29 M: 31821824 DEBUG: msg: --- HTTP DEBUG HEADER --- START ---
09:03:29 M: 31821824 DEBUG: msg: protocol: [HTTP/1.1]
09:03:29 M: 31821824 DEBUG: msg: http minor version: [1]
09:03:29 M: 31821824 DEBUG: msg: uri: [(null)]
09:03:29 M: 31821824 DEBUG: msg: method: [(null)]
09:03:29 M: 31821824 DEBUG: msg: status code: [200]
09:03:29 M: 31821824 DEBUG: msg: reason phrase: [OK]
09:03:29 M: 31821824 DEBUG: msg: body size: [0]
09:03:29 M: 31821824 DEBUG: msg: Fields:
09:03:29 M: 31821824 DEBUG: msg: 0 - Date: Sat, 01 Jan 0000 00:00:00 GMT
09:03:29 M: 31821824 DEBUG: msg: 1 - Server: RT-Platform/1.0 UPnP/1.0 EBS Mi
09:03:29 M: 31821824 DEBUG: msg: 2 - Connection: close
09:03:29 M: 31821824 DEBUG: msg: 3 - Content-Type: video/vnd.dlna.mpeg-tts
09:03:29 M: 31821824 DEBUG: msg: 4 - Accept-ranges: none
09:03:29 M: 31821824 DEBUG: msg: --- HTTP DEBUG HEADER --- END ---
09:03:29 M: 31821824 DEBUG: msg: Content-Type: [video/vnd.dlna.mpeg-tts]
09:03:29 M: 31821824 DEBUG: msg: Cache size set to 4096 KBytes
09:03:29 M: 31821824 DEBUG: msg: Connected to server: 192.168.1.5
09:03:29 M: 27074560 DEBUG: msg: CACHE_PRE_INIT: 0 [0] 0 pre:838860 eof:0
Cache fill: 0.00% (0 bytes)
09:03:30 M: 27074560 DEBUG: msg:
09:03:30 M: 27074560 DEBUG: msg: demux_open(00A90010,0,-1,-1,-1)
09:03:30 M: 27074560 DEBUG: msg: Checking for YUV4MPEG2
09:03:30 M: 27074560 DEBUG: msg: ASF_check: not ASF guid!
09:03:30 M: 27074560 DEBUG: msg: Checking for Nullsoft Streaming Video
09:03:30 M: 27074560 DEBUG: msg: Checking for NuppelVideo
09:03:30 M: 27074560 DEBUG: msg: Checking for REAL
09:03:30 M: 27074560 DEBUG: msg: Checking for SMJPEG
09:03:30 M: 27074560 DEBUG: msg: Searching demuxer type for filename
http://192.168.1.5:4097/8/video/mpeg/$03fd$0366.mpg ext: .mpg
09:03:30 M: 27074560 DEBUG: msg: Checking for MOV
09:03:30 M: 27074560 DEBUG: msg: Checking for VIVO
09:03:30 M: 27074560 DEBUG: msg: SUB: opened iconv descriptor.
09:03:30 M: 27062272 DEBUG: msg: SUB: closed iconv descriptor.
09:03:30 M: 27074560 DEBUG: msg: Checking for PVA
09:03:31 M: 27074560 DEBUG: msg: Checking for MPEG-TS...
09:03:31 M: 27074560 DEBUG: msg: THIS DOESN'T LOOK LIKE AN MPEG-TS FILE!
09:03:31 M: 27074560 DEBUG: msg: TRIED UP TO POSITION 0, FOUND ffffff00, packet_size= 0, SEEMS A TS? 0
09:03:31 M: 27074560 DEBUG: msg: Checking for LMLM4 Stream Format
09:03:31 M: 27074560 DEBUG: msg: cache_stream_seek: WARNING! Can't seek to 0xFFFFFFFFFFFFFFF8 !
09:03:31 M: 27074560 DEBUG: msg: LMLM4 Stream Format not found
09:03:31 M: 27074560 DEBUG: msg: MPEG Stream reached EOF
09:03:31 M: 27074560 DEBUG: msg: ds_fill_buffer: EOF reached (stream: video)
09:03:31 M: 27074560 DEBUG: msg: MPEG packet stats: p100: 0 p101: 0 p1B6: 0 p12x: 0 sli: 0 a: 0 b: 0 c: 0 idr: 0 sps: 0 pps: 0 PES: 0 MP3: 0, synced: 0
09:03:31 M: 27074560 DEBUG: msg: Not MPEG System Stream format... (maybe Transport Stream?)
09:03:31 M: 27074560 DEBUG: msg: demux_aac_probe, failed to detect an AAC stream
09:03:31 M: 27054080 DEBUG: msg: ds_fill_buffer: EOF reached (stream: video)
09:03:31 M: 27074560 ERROR: CMPlayer::OpenFile
http://192.168.1.5:4097/8/video/mpeg/$03fd$0366.mpg failed with code -1
