2022-04-21, 22:11
2022-04-21, 22:20
yes I can look at contents.
2022-04-21, 22:29
Ok, try this:
1. Open the dmg and drag adbLink app to your desktop
2. Open terminal
3. paste this into terminal: open -a ~/Desktop/adbLink.app
Note any error messages.
2. Open terminal
2022-04-21, 22:35
Tried that , get the pop up "adblink is damaged and can't be opened. You should move it to Bin. "
2022-04-21, 22:36
OK, thanks. Nothing is ever easy
2022-04-21, 22:41
OK on link2 , got some errors showing up in terminal
The application /Users/jrmac/Desktop/adbLink.app cannot be opened for an unexpected reason, error=Error Domain=NSCocoaErrorDomain Code=260 The file “adbLink.app” couldn’t be opened because there is no such file." UserInfo={NSURL=file:///Users/jrmac/Desktop/adbLink.app, NSFilePath=/Users/jrmac/Desktop/adbLink.app, NSUnderlyingError=0x126619480 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}.
2022-04-21, 23:21
No idea whats occurring here. I just downloaded both dmg files, they opened w/o error and both programs work fine.
Here are links to zip files rather than dmg archives.
http://www.jocala.com/adblink1.zip
http://www.jocala.com/adblink2.zip
Just downloaded both zips they unzip and the programs run w/o error.
2022-04-21, 23:58
2022-04-22, 04:26
NOTE: adbLink 4.9 has been pulled due to build issues. If you downloaded v4.9 please visit http://www.jocala.com and download adbLink v5.0. Thank you and sorry for the bother!
2022-04-22, 19:00
M1 Beta: You may get an error message when opening these apps saying they are damaged and should be deleted. Fix this with the terminal command: "xattr -cr /path/to/adbLink.app". No idea why Mac is marking these apps as damaged. Investigating ...
Edit: Fixed. The installation file is now in pkg format.
2022-04-25, 20:16
Beta 2 of adbLink for Apple Silicon is available at http://www.jocala.com
2022-04-28, 17:32
Beta3 of Mac adbLink 5.0 is available at http://www.jocala.com.
This release is a universal binary that runs on either Intel or Apple Silicon, so any Mac user can run it. Beta feedback is gratefully appreciated.
2022-08-08, 18:14
08/08/22
adbLink 5.1 release
Internal script directory made
uniform for all architectures.
Terminal selection expanded.
Preferences now allows you to
choose Windows Terminal or
Command Prompt for Windows,
Terminal or iTerm for macOS,
and Gnome Terminal, KDE Console
or XFCE4 Terminal for Linux.
Initial support for Intel ChromeOS.
Tested with ChromeOS Flex.
adbLink 5.1 release
2022-08-09, 06:55
Just updated from 5.0 to 5.1 on a Windows 10 PC and I can no longer connect to my device via USB.
5.0 connected fine then asked if I wanted to update to 5.1. I said yes and downloaded/installed it and now no USB connection.
Reverted to 5.0 and USB connection works again.
2022-08-09, 08:39
(2022-08-09, 06:55)arsMOBILIS Wrote: [ -> ]Just updated from 5.0 to 5.1 on a Windows 10 PC and I can no longer connect to my device via USB.FWIW, just tested two different Android devices via USB on Win 10 and other than the customary prompt to allow the ADB connection on each device, I encountered no issues whatsoever.
