Full Version: adbLink 4.7: Windows/Mac/Linux Companion for Kodi
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
To switch back and forth between kodi and spmc you'll need to change the settings in the device record. Multiple records with the same IP won't work.
This video shows how:  ​​​​​
https://youtu.be/TEVU3NRE-m8
(2018-01-06, 14:56)jocala Wrote: [ -> ]To switch back and forth between kodi and spmc you'll need to change the settings in the device record. Multiple records with the same IP won't work.
 ok. thx for the answer
New video:  Cloning Desktop Kodi (Windows/Mac/Linux) to an Android device.
https://youtu.be/Cq9RSmO4bDE
Awesome thank you. When restore... wipe and restore or just add?
Example 1.
If android has addon1 and backup has addon1 and addon2. Does restore add addon2 and leave addon1 as is or does it overwrite addon1 and add addon2?
Example 2.
If android has addon1 and backup has addon2 and addon3. Does the restore remove addon1 and add addon2/3 or does it just add addon2/3 and leave addon1 as is?
Thank you
An adbLink backup is a complete snapshot of a Kodi filesystem and restore completely replaces the Kodi filesystem on the target.
I have a Fire TV with a pin lock on the settings, is there away to use adb to do a factory reset without the pin?
adbLink v 3.6 released
/sdcard, /data/local/tmp, & /storage
added to presets for file manager
Activity indicator for local restores
now properly resets when job is done.
File manager checks that preset
or ad hoc path exists prior to
directory change via go button.
Android Debug Bridge updated
Version 1.0.39 - 0.0.1-4500957
File manager updated to work with
adb v1.0.39
Fastboot updated
Version 0.0.1-4500957
http://www.jocala.com
(2018-02-20, 19:54)jocala Wrote: [ -> ]No.  This might help: http://www.aftvnews.com/how-to-unbrick-b...n-fire-tv/
 Thank you
I'm new to this and I have been able to copy my build to other fire stick that I have. I am now not able to restore a build I have because I am getting a error "Cannot restore while org.xbmc.kodi is running!".
You need to close Kodi on the device being restored. You can do this with adbLink's Utility Menu function "Stop Application".
OK. So I stopped the application and continued to restore. After restoration the Kodi build on the fire stick is just Kodi without the addons.
A restore replaces your Kodi filesystem with a backed up Kodi filesystem, usually the contents of /sdcard/Android/data/org.xbmc.kodi. If you're having backup/restore issues with an official addon from the Kodi repository you can post details here. Otherwise, send an email to [email protected]jocala.com
Should I post the kodi log? Because it seems the addons were installed but I had to individually enable each one. Even then it doesn't look the same.
If you're not dealing with an official Kodi addon, you can't discuss specifics on this forum, it's forbidden.
