Full Version: [REQUEST] 1 Image Gif Screensaver
Hi Ladies & Gentlemen im new here and wanted to know if there is anything out/in the making for this. I want a screensaver to show a single animated gif image at a time. Inside the config there should be a option to select from 3 different Gifs.
Is there anything out yet? Ive been looking. Closest thing ive found is the Snowy Screensaver. I Have python and have opened the config file and tried to impliment the gifs into it but failed. Any help would be appreciated!
Thanks, no0BsCEnE
Hi no0BsCENE,
Welcome to the forum.
I have added support for "gif" images to the following version of TvTunesScreensaver.
https://drive.google.com/file/d/0B1v3j95...sp=sharing
If you go to the settings and select:
Image Source: Folder
Then set the folder location to somewhere containing you gifs.
You can try out the different "Screensaver Types" - TableDrop is normally a good starting point Big Grin
Hopefully that gives you something close to what you are looking for.
Rob
P.S. Just because the screensaver links with TvTunes, doesn't mean it can't just display custom images for you Big Grin
thread should be deleted as user who replied is banned and there is no useful info
