Missing IPTV SIMPLE CLIENT: hello there. I can't find out PVR IPTV. I'm using kodi 16. I had reset my MXQ box but I didn't get the solution. I will appreciate some help. Thanks
The PVR clients are shipped with Kodi on each platform except Linux; for Linux installations you must either install from your distro's repositories or compile from source.
If you have android+Kodi you must enable it myaddon>pvrclient.
If you have OpenELEC/LibreELEC install from OE/LE repo>pvrclient.
Inviato dal mio Nexus 5X utilizzando Tapatalk
I have Kodi 16.1 using Android. My System never had any PVR INCLUDING PVR SIMPLE CLIENT. Trying to find out how to locate and load the Simple Client. Thanks,
If you reinstall Kodi, it will install the PVR clients again.
