2016-06-03, 11:19
Hi guys anyone can help me to compile from source for Raspberry Pi2/3 and installit manually?
Without use kodi addons extension.
Thank you
Thank you
(2016-06-05, 19:06)rpcameron Wrote: [ -> ]What is Jodi? That is a distribution I am unfamiliar with. Is there a base distro that it uses as its source?
(2016-06-06, 00:14)rpcameron Wrote: [ -> ]Kodi is the application. But the instructions for getting PVR clients compiled and/or installed depends upon your operating system. Are you using OpenELEC/LibreELEC? Ubuntu, Debian, Mint, Arch, &c. The list is quite extensive, and instructions will vary upon which distribution and which version of that distribution you are using. Because the instructions are so tied to your actual operating system rather than which version of Kodi, the first (and perhaps best) place to look for this information is through your OS provider, because Kodi on Linux (including on the Raspberry Pi) does not ship with any PVR client.
(2016-06-07, 01:52)rpcameron Wrote: [ -> ]OpenELEC has a repository already configured in their distribution for PVR clients. You add/install it the same way you do any other add-on, from the Settings > Add-ons screen
As far as source compiling, OpenELEC is not a full distribution, so they do not provide any development tools in the OS. But if they provide the binary add-ons, why do you need to compile?
(2016-06-07, 10:36)robello84 Wrote: [ -> ]I downloaded the OpenELEC image file, mounted it, and was able to browse its filesystem to find the address of OE's repository. From there, I found what you are looking for: http://addons.openelec.tv/7.0/RPi2/arm/p....12.12.zip(2016-06-06, 00:14)rpcameron Wrote: [ -> ]Kodi is the application. But the instructions for getting PVR clients compiled and/or installed depends upon your operating system. Are you using OpenELEC/LibreELEC? Ubuntu, Debian, Mint, Arch, &c. The list is quite extensive, and instructions will vary upon which distribution and which version of that distribution you are using. Because the instructions are so tied to your actual operating system rather than which version of Kodi, the first (and perhaps best) place to look for this information is through your OS provider, because Kodi on Linux (including on the Raspberry Pi) does not ship with any PVR client.
Because i need the zip file for openelec
