Full Version: Need help with RSS Editor
I've run into the following problem when trying to edit the RSS feed in the RSS Editor addon. When I click on edit under settings, I get an error. Can someone help me interpret the error string below. Sorry I'm not that good with XML.
22:23:13 T:18216    INFO: initializing python engine.
22:23:13 T:18216   DEBUG: CPythonInvoker(117, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): start processing
22:23:13 T:18216   DEBUG: -->Python Interpreter Initialized<--
22:23:13 T:18216   DEBUG: CPythonInvoker(117, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): the source file to load is "C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py"
22:23:13 T:18216   DEBUG: CPythonInvoker(117, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): setting the Python path to C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
22:23:13 T:18216   DEBUG: CPythonInvoker(117, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): entering source directory C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor
22:23:13 T:18216   DEBUG: CPythonInvoker(117, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): instantiating addon using automatically obtained id of "script.rss.editor" dependent on version 2.1.0 of the xbmc.python api
22:23:13 T:18216   DEBUG: [SCRIPT] '<xbmcaddon.Addon object at 0x1A731CE0>: version 2.0.4' initialized!
22:23:13 T:18216   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'NoneType' object has no attribute 'toxml'
                                              File "C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py", line 17, in <module>
                                                ui = rssEditor.GUI("script-RSS_Editor-rssEditor.xml", __cwd__, "default", setNum = 'set1')
                                              File "C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\resources\lib\rssEditor.py", line 14, in __init__
                                                self.parser = XMLParser()
                                              File "C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\resources\lib\xmlParser.py", line 66, in __init__
                                                self.feedsList = self.getCurrentRssFeeds()
                                              File "C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\resources\lib\xmlParser.py", line 90, in getCurrentRssFeeds
                                                feedsList[setName]['feedslist'].append({'url':feed.firstChild.toxml(), 'updateinterval':feed.attributes['updateinterval'].value})
                                            AttributeError: 'NoneType' object has no attribute 'toxml'
22:23:13 T:8292   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
22:23:13 T:49564   DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
Tough to tell from a partial log except that it seems you are running Windows and that there seems to be a versioning dependency issue.
I just tested the RSS editor 2.0.4 on Kodi 16.1 on Win7 with no issue.
What versions do you have and have you attempted a re-install?
(2016-06-05, 04:38)OTinley Wrote: [ -> ]Hi,
Thank you for the quick reply. Yes, I am running Windows 10. I am using RSS Editor ver. 2.0.4 and I'm running KODI Jarvis with AEON MQ6 skin.
I posted below my entire debug log for execution of the RSS Editor.
02:03:01 T:54244  NOTICE: special://profile/ is mapped to: special://masterprofile/
02:03:01 T:54244  NOTICE: -----------------------------------------------------------------------
02:03:01 T:54244  NOTICE: Starting Kodi (16.1 Git:20160424-c327c53). Platform: Windows NT x86 32-bit
02:03:01 T:54244  NOTICE: Using Release Kodi x32 build
02:03:01 T:54244  NOTICE: Kodi compiled Apr 24 2016 by MSVC 180040629 for Windows NT x86 32-bit version 6.0 (0x06000000)
02:03:01 T:54244  NOTICE: Running on HP-Pavilion VT637AAR-ABA HPE-112Y with Windows 10, kernel: Windows NT x86 64-bit version 10.0
02:03:01 T:54244  NOTICE: Host CPU: AMD Phenom(tm) II X4 925 Processor, 4 cores available
02:03:01 T:54244  NOTICE: Desktop Resolution: 1920x1200 32Bit at 59Hz
02:03:01 T:54244  NOTICE: Running with administrator rights
02:03:01 T:54244  NOTICE: Aero is enabled
02:03:01 T:54244  NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
02:03:01 T:54244  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
02:03:01 T:54244  NOTICE: special://masterprofile/ is mapped to: C:\Users\Conrad\AppData\Roaming\Kodi\userdata
02:03:01 T:54244  NOTICE: special://home/ is mapped to: C:\Users\Conrad\AppData\Roaming\Kodi\
02:03:01 T:54244  NOTICE: special://temp/ is mapped to: C:\Users\Conrad\AppData\Roaming\Kodi\cache
02:03:01 T:54244  NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
02:03:01 T:54244  NOTICE: Local hostname: MAIN-PC
02:03:01 T:54244  NOTICE: Log File is located: C:\Users\Conrad\AppData\Roaming\Kodi\kodi.log
02:03:01 T:54244  NOTICE: load settings...
02:03:01 T:54244 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
02:03:01 T:54244 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
02:03:01 T:54244  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
02:03:01 T:54244  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
02:03:01 T:54244  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <!-- Created using Easy Advanced Settings addon -->
                                            <advancedsettings>
                                              <network>
                                                <buffermode>2</buffermode>
                                                <cachemembuffersize>157286400</cachemembuffersize>
                                                <readbufferfactor>20</readbufferfactor>
                                              </network>
                                              <fanartres>500</fanartres>
                                              <imageres>800</imageres>
                                            </advancedsettings>
02:03:01 T:54244  NOTICE: Default DVD Player: dvdplayer
02:03:01 T:54244  NOTICE: Default Video Player: dvdplayer
02:03:01 T:54244  NOTICE: Default Audio Player: paplayer
02:03:01 T:54244  NOTICE: Disabled debug logging due to GUI setting. Level 0.
02:03:01 T:54244  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
02:03:01 T:54244  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
02:03:01 T:54244  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
02:03:01 T:54244  NOTICE: Loaded playercorefactory configuration
02:03:01 T:54244  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
02:03:01 T:54244  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
02:03:01 T:54244  NOTICE: CWakeOnAccess::LoadFromXML - unable to load:C:\Users\Conrad\AppData\Roaming\Kodi\userdata\wakeonlan.xml
02:03:01 T:55260  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "Digital Audio (HDMI) (High Definition Audio Device)" seems to be not supported.
02:03:01 T:55260  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "Digital Audio (HDMI) (High Definition Audio Device)" seems to be not supported.
02:03:01 T:55260  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "Digital Audio (HDMI) (High Definition Audio Device)" seems to be not supported.
02:03:01 T:55260  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "Digital Audio (HDMI) (High Definition Audio Device)" seems to be not supported.
02:03:01 T:55260  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "Digital Audio (HDMI) (High Definition Audio Device)" seems to be not supported.
02:03:01 T:55260  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "Digital Audio (HDMI) (High Definition Audio Device)" seems to be not supported.
02:03:01 T:55260  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "Digital Audio (HDMI) (High Definition Audio Device)" seems to be not supported.
02:03:02 T:55260  NOTICE: Found 2 Lists of Devices
02:03:02 T:55260  NOTICE: Enumerated DIRECTSOUND devices:
02:03:02 T:55260  NOTICE:     Device 1
02:03:02 T:55260  NOTICE:         m_deviceName      : {BACB1F3E-B1C8-4465-A424-FB9487C28055}
02:03:02 T:55260  NOTICE:         m_displayName     : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
02:03:02 T:55260  NOTICE:         m_displayNameExtra: DIRECTSOUND: Realtek Digital Output (Realtek High Definition Audio)
02:03:02 T:55260  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
02:03:02 T:55260  NOTICE:         m_channels        : FL,FR
02:03:02 T:55260  NOTICE:         m_sampleRates     : 48000
02:03:02 T:55260  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
02:03:02 T:55260  NOTICE:     Device 2
02:03:02 T:55260  NOTICE:         m_deviceName      : {BC6838E6-BBB9-4C34-849C-CF1065C502B1}
02:03:02 T:55260  NOTICE:         m_displayName     : HDMI - Digital Audio (HDMI) (High Definition Audio Device)
02:03:02 T:55260  NOTICE:         m_displayNameExtra: DIRECTSOUND: Digital Audio (HDMI) (High Definition Audio Device)
02:03:02 T:55260  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
02:03:02 T:55260  NOTICE:         m_sampleRates     : 44100
02:03:02 T:55260  NOTICE:     Device 3
02:03:02 T:55260  NOTICE:         m_deviceName      : {F918E742-2DE3-4026-9D89-B92F4B7779D5}
02:03:02 T:55260  NOTICE:         m_displayName     : Speakers - Speakers (Realtek High Definition Audio)
02:03:02 T:55260  NOTICE:         m_displayNameExtra: DIRECTSOUND: Speakers (Realtek High Definition Audio)
02:03:02 T:55260  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
02:03:02 T:55260  NOTICE:     Device 4
02:03:02 T:55260  NOTICE:         m_deviceName      : default
02:03:02 T:55260  NOTICE:         m_displayName     : default
02:03:02 T:55260  NOTICE: Enumerated WASAPI devices:
02:03:02 T:55260  NOTICE:         m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
02:03:02 T:55260  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
02:03:02 T:55260  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
02:03:02 T:55260  NOTICE:         m_displayNameExtra: WASAPI: Digital Audio (HDMI) (High Definition Audio Device)
02:03:02 T:55260  NOTICE:         m_sampleRates     : 192000,48000,44100,32000
02:03:02 T:55260  NOTICE:         m_dataFormats     : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
02:03:02 T:55260  NOTICE:         m_displayNameExtra: WASAPI: Speakers (Realtek High Definition Audio)
02:03:02 T:55260  NOTICE:         m_channels        : FL,FR,FC,LFE,SL,SR,BL,BR
02:03:02 T:55260  NOTICE:         m_dataFormats     : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
02:03:02 T:54244  NOTICE: Running database version Addons20
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.exodus
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.kodil
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.xxxadultxbmc
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.Rodrigo
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.bbtsip.tv
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.mods-kodi
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.sd-xbmc.org
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.boogie
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.filmkodi.com
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.BassFox-Official
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.BlazeRepo
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.noobsandnerds
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.phantom
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.dudehere.plugins
02:03:02 T:54244  NOTICE: ADDONS: Using repository repo.natko1412
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.OperationRobocop
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.featherence
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.iWillFolo.xbmc
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.shani
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.podgod
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.xbmcadult
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.tknorris.release
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.RenegadesTV
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.Kinkin
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.eldorado
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.xbmchub
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.VinManJSV
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.foreverguest
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.mdrepo
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.xbmc.org
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.xbmc-israel
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.awesome
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.metalkettle
02:03:02 T:54244  NOTICE: ADDONS: Using repository xbmc.repo.ivueguide
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.entertainmentrepobackup
02:03:02 T:54244  NOTICE: ADDONS: Using repository repository.whitecream
02:03:02 T:54244  NOTICE: Found screen: HP w2408 Wide LCD Monitor on ATI Radeon HD 4300/4500 Series, adapter 0.
02:03:02 T:54244  NOTICE: Found screen: HP w2408 Wide LCD Monitor on ATI Radeon HD 4300/4500 Series, adapter 1.
02:03:02 T:54244  NOTICE: Primary mode: 1920x1200@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Secondary mode: 1920x1200@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Previous line repeats 2 times.
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x960@ 30.00i - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 800x600@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 848x480@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 848x480@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x648@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x648@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x900@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1360x1024@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1600x1000@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 25.00i - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 30.00i - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1200@ 59.94 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1200@ 60.00 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 640x480@ 75.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 29.97i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 30.00i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x480@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x576@ 25.00i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x576@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 720x960@ 30.00i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 800x600@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 800x600@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 800x600@ 75.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 848x480@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 848x480@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1024x768@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1024x768@ 75.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x648@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x648@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x648@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1152x864@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x720@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x720@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x720@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x768@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x800@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x900@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x960@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x1024@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1280x1024@ 75.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1360x768@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1360x1024@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1440x900@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1600x1000@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1600x1200@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1680x1050@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1680x1050@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 25.00i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 30.00i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1776x1000@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 25.00i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 29.97i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 30.00i #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 50.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1080@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1200@ 59.94 #2 - Full Screen
02:03:02 T:54244  NOTICE: Additional mode: 1920x1200@ 60.00 #2 - Full Screen
02:03:02 T:54244  NOTICE: Checking resolution 16
02:03:02 T:54244   ERROR: Window Translator: Can't find window filestackingdialog
02:03:02 T:54244   ERROR: Previous line repeats 1 times.
02:03:02 T:54244  NOTICE: Running database version ViewModes6
02:03:02 T:54244  NOTICE: Running database version Textures13
02:03:02 T:54244  NOTICE: Running database version MyMusic56
02:03:02 T:54244  NOTICE: Running database version MyVideos99
02:03:02 T:54244  NOTICE: Running database version TV29
02:03:02 T:54244  NOTICE: Running database version Epg11
02:03:03 T:54244 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
02:03:03 T:54244  NOTICE: DVDPlayer: Opening: special://media/introMovie.mp4
02:03:03 T:54244 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
02:03:03 T:17900  NOTICE: Creating InputStream
02:03:03 T:17900   ERROR: CDVDPlayer::OpenInputStream - error opening [special://media\introMovie.mp4]
02:03:03 T:17900  NOTICE: CDVDPlayer::OnExit()
02:03:03 T:54244   ERROR: PlayMedia could not play media: special://media\introMovie.mp4
02:03:03 T:54244  NOTICE: ActiveAE DSP - starting
02:03:03 T:54244   ERROR: CScriptInvocationManager::ExecuteAsync - Not executing non-existing script C:\Users\Conrad\AppData\Roaming\Kodi\addons\plugin.audio.jango\playerMP3.py
02:03:03 T:54244   ERROR: CScriptInvocationManager::ExecuteAsync - Not executing non-existing script C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.navi-x\service.py
02:03:03 T:54244  NOTICE: initialize done
02:03:03 T:54244  NOTICE: Running the application...
02:03:04 T:54244  NOTICE: CDVDPlayer::CloseFile()
02:03:04 T:54244  NOTICE: DVDPlayer: waiting for threads to exit
02:03:04 T:54244  NOTICE: DVDPlayer: finished waiting
02:03:04 T:54244  NOTICE: starting upnp client
02:03:04 T:16932  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
02:03:04 T:16932  NOTICE: UDP: Listening on port 9777
02:03:12 T:16096  NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Starting NextUp Service
02:03:12 T:16096  NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ========  START NEXTUP SERVICE NOTIFICATION  ========
02:03:12 T:16096  NOTICE: NEXTUP SERVICE NOTIFICATION Service -> KODI Version: 16.1 Git:20160424-c327c53
02:03:12 T:16096  NOTICE: NEXTUP SERVICE NOTIFICATION Service -> NEXTUP SERVICE NOTIFICATION Version: 1.0.25
02:03:12 T:16096  NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Platform: Windows
02:03:12 T:51916  NOTICE: Skin Helper Service --> skin helper service version 1.0.90 started
02:03:12 T:51916  NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
02:03:13 T:26304  NOTICE: SCRIPT.SERVICE.LASTVK: Last.VK service started
02:03:14 T:31856  NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.05.21.2
02:03:14 T:31856  NOTICE: version 4.6.1 started
02:03:14 T:31856  NOTICE: finished
02:03:18 T:31024  NOTICE: [TVonline] Subscription service starting...
02:03:18 T:50636  NOTICE: [TV4ME] Subscription service starting...
02:03:18 T:47844  NOTICE: DudeHere Common Routines Service: Starting...
                                            MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
                                            MMMMMMMMMMMMMMMMM DudeHere - 2016 - http://forums.tvaddons.ag MMMMMMMMMMMMMMMMMM
02:03:18 T:47844  NOTICE: DudeHere Common Routines Service: Version: 0.4.22
02:03:18 T:47844  NOTICE: DudeHere Common Routines Service: Repository installed: True
02:03:18 T:47844  NOTICE: DudeHere Common Routines Service: Transmogrifier installed: False
02:03:18 T:47844  NOTICE: DudeHere Common Routines Service: Walter Sobchak installed: False
02:03:18 T:52024  NOTICE: 1Channel: Service: Installed Version: 2.5.77
02:03:18 T:52024  NOTICE: 1Channel: Loading sqlite3 as DB engine
02:03:18 T:53784  NOTICE: Stream All The Sources: Service: Installed Version: 2.0.28
02:03:19 T:52024  NOTICE: 1Channel: Service: Resetting...
02:03:19 T:52024  NOTICE: 1Channel: Service: starting...
02:03:19 T:41088  NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.05.21.2
02:03:19 T:41088  NOTICE: version 4.6.1 started
02:03:20 T:53784  NOTICE: Stream All The Sources: Service: starting...
02:03:20 T:49372  NOTICE: [SPECTO]: ->----------                PARAMS: {'action': 'service'}
02:03:20 T:49372  NOTICE: [SPECTO]: ->----------                PARAMS2: ?action=service
02:03:20 T:41088 WARNING: Attempt to use invalid handle 3
02:03:20 T:41088 WARNING: Previous line repeats 29 times.
02:03:20 T:41088  NOTICE: finished
02:03:28 T:20220   ERROR: XFILE::CDirectory::GetDirectory - Error getting
02:03:28 T:18240  NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.05.21.2
02:03:28 T:18240  NOTICE: version 4.6.1 started
02:03:28 T:18240 WARNING: Attempt to use invalid handle 4
02:03:28 T:18240 WARNING: Previous line repeats 29 times.
02:03:28 T:18240  NOTICE: finished
02:03:29 T:29892   ERROR: XFILE::CDirectory::GetDirectory - Error getting
02:03:53 T:54244  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
02:03:53 T:54244  NOTICE: Enabled debug logging due to GUI setting. Level 2.
02:03:53 T:54244   DEBUG: ------ Window Init () ------
02:03:56 T:54244   DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
02:03:56 T:54244   DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
02:03:56 T:54244   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
02:03:56 T:54244   DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
02:03:56 T:54244   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
02:03:56 T:54244   DEBUG: ------ Window Init (Settings.xml) ------
02:04:00 T:54244   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
02:04:02 T:54244   DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
02:04:02 T:54244   DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
02:04:03 T:54244   DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
02:04:03 T:54244   DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
02:04:04 T:54244   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
02:04:04 T:54244   DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
02:04:04 T:54244   DEBUG: Activating window ID: 10019
02:04:04 T:54244   DEBUG: ------ Window Deinit (Settings.xml) ------
02:04:04 T:54244   DEBUG: ------ Window Init (SettingsCategory.xml) ------
02:04:05 T:54244   DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
02:04:05 T:54244   DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
02:04:06 T:54244   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
02:04:06 T:54244   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
02:04:07 T:54244   DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
02:04:07 T:54244   DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
02:04:08 T:54244   DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
02:04:08 T:54244   DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
02:04:08 T:45276   DEBUG: Thread LanguageInvoker start, auto delete: false
02:04:08 T:45276    INFO: initializing python engine.
02:04:08 T:45276   DEBUG: CPythonInvoker(34, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): start processing
02:04:08 T:45276   DEBUG: -->Python Interpreter Initialized<--
02:04:08 T:45276   DEBUG: CPythonInvoker(34, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): the source file to load is "C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py"
02:04:08 T:45276   DEBUG: CPythonInvoker(34, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): setting the Python path to C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
02:04:08 T:45276   DEBUG: CPythonInvoker(34, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): entering source directory C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor
02:04:08 T:45276   DEBUG: CPythonInvoker(34, C:\Users\Conrad\AppData\Roaming\Kodi\addons\script.rss.editor\default.py): instantiating addon using automatically obtained id of "script.rss.editor" dependent on version 2.1.0 of the xbmc.python api
02:04:08 T:45276   DEBUG: [SCRIPT] '<xbmcaddon.Addon object at 0x1966B560>: version 2.0.4' initialized!
02:04:08 T:45276 WARNING: CSkinInfo: failed to load skin settings
02:04:08 T:45276   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
02:04:08 T:54244   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
02:04:09 T:45276    INFO: Python script stopped
02:04:09 T:45276   DEBUG: Thread LanguageInvoker 45276 terminating
02:04:14 T:54244   DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
02:04:17 T:54244    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to https://www.dropbox.com (easy=0D765688, multi=0D124C40)
02:04:18 T:54244   DEBUG: ------ Window Init (Pointer.xml) ------
02:04:20 T:54244   DEBUG: CWinEventsWin32::WndProcWindow is active
02:04:20 T:54244   DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
02:04:23 T:54244   DEBUG: ------ Window Deinit (Pointer.xml) ------
Removing the banned add-ons (wiki) might help.
(2016-06-05, 15:10)MetalChris Wrote: [ -> ]Removing the banned add-ons (wiki) might help.
Why would that make any difference?
Sent from my iPhone
(2016-06-05, 16:07)spoyser Wrote: [ -> ]
Sent from my iPhone
You'll notice in the log that a number of the banned add-ons are starting, and running, numerous background services. These may be interfering with proper operation, and consuming unnecessary resources. Of course, it's entirely possible that my suggestion may make no difference at all, but it's been my experience that a cleaner, leaner system will run better, and have less issues. It's also been my experience that people with banned add-ons installed receive less help from this community, so removing them may result in more suggestions from more knowledgeable people than myself.
