Full Version: Video folder doesn't refresh.
Unsure if this is the correct location so if not I apologize in advance.
I have set a video folder with movie trailers as a source and set the folder to be accessed from the main menu. For some reason the list of files in the folder will not refresh even though files have been added and removed from the physical folder. This happens in a custom skin as well as the default skin I think is called conflence? The list the folder shows is old and half the files it it don't work because the video has been deleted. Is there a way to correct the list so it will refresh?
Thank you for your advice in advance.
