Full Version: Add season and episode number on the top bar while video is playing.
Hi
I just want to add next to the TVShow name label the season and number of the episode like 6x05.
And I don't know which xml should I edit.
http://i.imgur.com/fZwpDJ8.jpg%5B/img%5D
Hope someone can help me.
You need to supply a bit more information for someone to be able to help you if possible? Things like the skin / skin mod you are using, your version of Kodi.
You might want to ask in the sub-forum of the skin you are using as well instead of general 'skin support'
But the additional information is needed to start with and allow someone to have a chance of helping you.
