Skins Support
Estuary
> How to play a DVD
Full Version:
How to play a DVD
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
cu_shane
2016-06-05, 18:51
When I put a DVD in my computer, I don't see how I can play it with this skin? i.e. I don't see Play DVD or anything similar show up as a menu choice. Any guidance?
cu_shane
2016-06-07, 14:34
So there is no way to play a DVD disk while using this skin? That can't be right...
Av3nged
2016-06-07, 15:55
On the main menu go down to video then when you put in a DVD an icon in the submenu will pop up at the top.
cu_shane
2016-06-07, 16:47
Skins Support
Estuary
> How to play a DVD
