Full Version: [Raspbian] Black screen
I have Raspberry pi 3 with installed Raspbian, and instaled Kodi 15.
When I try started any movie (using Kodi) than I have only black screen (I dont have any picture) only sound, I have this problem also with youtube and another wideo plugins.
Any ideas?
Have you set gpu_mem to 256 in config.txt?
If that is not the fix post a debug log (wiki)
do you mean config.txt in raspbian or some config file for Kodi?
Where I can found this file?
Should be /boot/config.txt from raspbian.
OK I will try it do today Smile
