Full Version: Manually modify "DateAdded" for Episodes
Hi all,
I just learned, that Kodi uses filedate / file changed dated by default for "DateAdded".
I also learned, that this could be changed by using advancedxml setting.
However, I just imported a TV Show with 7 seasons using standard setting (Filedate).
As Filedates are partially back in 2011, the recently added list does not show them.
I changed setting in advancedsetting XML already but is there any way to manually update the dateadded for the seven seasons without reimporting them?
